Hi,
Wondering if anyone can Help! please,
My Grandson's (10year old) HP Laptop has a Problem, i've tried all sorts of things to solve it but can't  :unsure: I have improved it a tiny bit,
What it is....is...
When I press the Start button and it opens up to show- search programs and files- >All programs  and recently used programs
Its flashing/highlighting what's on there from bottom to top constantly and if i try to click one of them i miss and it open another from that list
while its rotating through them (hard to explain) It does this when in all program too,
If i miss the progarm i'm trying to open and another one opens on the desktop the OK -  Cancel buttons flash from one to the other
Its like a Ghost has it's Bony finger on the up/down Left/right keys  :o .....Heeeelp!
Once or twice If i hit either the Ctrl - End - Esc keys it stalls it for a bit  but then it starts up again,
It has no Malware on Malwarebytes+camelion and other tools I've put on has seen to that, No viruses,
Anyone seen this before or knows how to sort it....Before i take a Sledge hammer to it  :wacko: Please?
Thank you in advance for help and info Ladies and Gents  :)
https://linustechtips.com/topic/329801-laptop-problem/
it might be your mouse or usb port try a different mouse
But i kind of feel sorry for your grandson 10 year old lap top makes me sad
retro is cool to look at but not to use on a normal basis.  I would recommend a new laptop.
Thank you,
It's not the laptop that's 10 years old..My Grandson is 10,
Not using a mouse I'm using the touch pad,
Thank you again Sir,
https://linustechtips.com/topic/329801-laptop-problem/#findComment-4477534
Thank you,
you may have a bad touch pad you can try calibrating it in the mouse settings also make sure there's nothing stuck to the pad you can clean it with a little water on a rag
https://linustechtips.com/topic/329801-laptop-problem/#findComment-4477540
Thank you again,
I will check and wipe etc and get back tomorrow,
Have a Nice day/evening Kind regards,
Les
https://linustechtips.com/topic/329801-laptop-problem/#findComment-4477617
