fan cfm
Solved by SonoDanshi,
Generally speaking (but not always) the larger the fan is the slower it needs to spin to push the same amount of air. This means that if they are decent quality fans then they will run quieter than their smaller counterparts.
If possible look for larger fans that have variable speed (either through PWM or a fan controller) so you can vary the CFM, speed and volume of them to your liking.
kerriya ·
Posted in Cases and Mods0 -
octester ·
Posted in Troubleshooting1 -
DavidPatrascu ·
Posted in General Discussion5 -
1
2
bill well ·
Posted in Peripherals0 -
4
2
Ha-Satan ·
Posted in Networking3 -
1
play_circle_filled
Latest From ShortCircuit:
