built in audio
Go to solution Solved by MrRavens,
Built in one for that is actually pretty good. Even most mobo now a days are pretty good. I got x99 gaming 7 from msi. They already havesound blaster separated on the pcb, so you should be pretty good. Now don't get me wrong, you can defiantly look into some options. But you should be good.
- Fresher than a fruit salad.
https://linustechtips.com/topic/329441-built-in-audio/#findComment-4472367
Generally the onboard ones are fine unless you have specific needs for I/O ports that aren't available onboard.
I have a dedicated card myself but that's purely because my onboard audio "popped" every 30 seconds or so (first onboard sound that has ever done that for me).
duc sequere aut de via decede
CPU: i7 6800K | Mobo: MSI X99 Gaming Pro Carbon | GPU: SLI EVGA 980 Ti Hydro Copper | PSU: EVGA 1000P2 | Memory: 64 DDR4 Corsair Dominator Platinum | Storage: Samsung 950 Pro 512GB M.2 & Samsung 850 Evo 1TB| Case: Be Quiet! Dark Base Pro 900 | Display: Predator X34 & Dell U2715H | Cooling: Custom Loop
Custom hard line watercooled Fractal Node 202 ITX build log
https://linustechtips.com/topic/329441-built-in-audio/#findComment-4472371
