BFME 2 DISK PROBLEMS
Go to solution Solved by TDP_Equinox,
so this probably can't be resolved but i give it a shot anyway.
so i have BFME 2 (and BFME 1) the first BFME works just fine but the second one doesnt reason?
i dont have the disk but have the data still retrieved it from my old laptop but now when i try to launch it it says that i need the disk but i lost it D: .
i have all the data even de even the box where it came in with the code but not the cd so is there any work around so that i can play the game ?
and i know piracy maybe a option but idk :(
You can download a copy of the iso (legally or illegally, doesn't matter) and mount it.
If you have windows 8, you can literally right click>mount iso and it will work.
If you have windows 7, you can use something like poweriso to mount it.
From there, it should allow you to play it.
On 11/19/2014 at 2:14 PM, Syntaxvgm said:
You would think Ubisoft would support the Bulldozer based architectures more given their digging themed names like bulldozer, Piledriver, Steamroller and Excavator.
https://linustechtips.com/topic/329320-bfme-2-disk-problems/
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
https://linustechtips.com/topic/329320-bfme-2-disk-problems/#findComment-4473057
Acquiring the iso wouldn't be illegal. Had the disks worked, you would be able to extract it anyways. As long as you have the key, proving you own a license, you are in good standing. You just might be downloading it from someone who obtained it illegally. Basically, the files are free, the key is what you pay to own.
EDIT: This is how I see it at least. My thought process may be flawed.
FX-8350 | GA-990FXA-UD3 | G.SKILL 2x8GB 1600MHz | 1TB WD RE4 | CM Hyper 212 EVO | MSI R9 290x Lightning | Corsair AX860i | Silverstone FT05B-W
Pentium G3258 | MSI Z97 PC Mate | G.SKILL 4x4GB 1066MHz | 500GB Samsung 2.5" | Stock cooler | Pending GPU | EVGA 500B | Antec DF-35
GoPro Hero 3 Silver | Netgear R7000 Nighthawk with DD-WRT | HP Officejet Pro 8610 | Canon iP110 | AudioTechnica ATR2500 USB
Downdraft cooler for mITX board (new build) | Desk mount mic stand | Pop filter | Anti-vibration mount for microphone | mITX case | 3rd monitor (matching existing 23.1" | Intel Core i7-4790K (for mITX build)
https://linustechtips.com/topic/329320-bfme-2-disk-problems/#findComment-4473078
I 100% agree with you.
https://linustechtips.com/topic/329320-bfme-2-disk-problems/#findComment-4473097
what for software do i need for windows 7? and a iso what does the iso contain can i make one myself rather do it with my own data
https://linustechtips.com/topic/329320-bfme-2-disk-problems/#findComment-4485622
Best just to find a source online; there will be files from the iso that you don't have.
And PowerISO gives you the ability to mount an ISO in windows 7.
https://linustechtips.com/topic/329320-bfme-2-disk-problems/#findComment-4488382
