Graphic card overheating?
Go to solution Solved by flibberdipper,
If it's over 80C then you might want to do something. 90C and it needs help.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/328704-graphic-card-overheating/#findComment-4461857
Ok so I have a nividia 970 and when I run payday... i check my temperature and it says 54 c which is 129 degress f. is this safe?
Ye definitely. On my 970 G1 I hit 69c under load, but that's in a cramped mATX case. 54c is very good
"Rawr XD"
https://linustechtips.com/topic/328704-graphic-card-overheating/#findComment-4461893
