Python help
Go to solution Solved by Sauron,
First of all "input()" returns a string unless you specify you want something else. That means no matter what you write, a string is never going to be equal to the integers 1, 2 or 3 for python. Try
number = int(input("Enter number: "))
Hello,
I am trying to make a basic number programme on Python.
Here is my code.
number = input("Enter number: ")if number == 1:    print("\n\nI like the number 1 too")elif number == 2:    print("\n\nI like the number 2 too")elif number ==3:    print("\n\nI like the number 3 too")else:    print("\n\nThat number doesn't count!")input("\n\n\nPress enter to exit")
For some reason, whatever number I type, it prints:
If anyone could help, it would be great.
Thanks,
- Bego :)
https://linustechtips.com/topic/328547-python-help/
sudo chmod -R 000 /*
https://linustechtips.com/topic/328547-python-help/#findComment-4459994
