USB 3.0 not being recognized
Solved by SirReallySam,
"You can also try your hand at disabling the USB controller devices and reinstalling it. Now how do you do it? Go to the Start menu, click on Run and type ‘devmgmt.msc’. Now try locating the USB controllers in the list that appears on the window. Uninstall all the USB controllers and restart your machine."
http://anthonysmith.hubpages.com/hub/What-to-Do-When-USB-Ports-Not-Working
maybe... :)
