Hi guys, I want to know pls how much does the thermal paste really help the heat dispersion in a cpu\chip\gpu and how much better it is then putting a air cooler or water cooler without any paste ? how much heat it really transfer ?
When i'm not playing PC games i'm playing with my PC parts  Fans,Pumps,Filters,  :wub:  :wub:  :wub:
https://linustechtips.com/topic/327392-thermal-paste-cooling/
Please don't put on heatsinks without thermal paste. It is designed to connect the 2 metal bases with each other to get rid of the heat, it evens the surfaces. That and metal to metal contact doesn't really transfer heat efficiently.
New to Star Citizen? Look no further!
https://linustechtips.com/topic/327392-thermal-paste-cooling/#findComment-4446709
I would expect a stock cooler with thermal paste to perform better than a custom water cooling loop without thermal paste. What brand you use doesn't matter much, but not using any will hurt performance a lot. I still use an arctic silver 5 tube that must be over 10 years old, works perfectly fine.
https://linustechtips.com/topic/327392-thermal-paste-cooling/#findComment-4446737
lol u guys I tried it without once on a Pentium and it was so cool, I really didn't get it, but with no O.Cing never got more the 60c full load
don't remember the brand of the cooler 80% it was stock or the cpu but I sure I didn't hallucinate that :)
Edited by Benielishackove
https://linustechtips.com/topic/327392-thermal-paste-cooling/#findComment-4446749
Yes. Thermal paste is 100% mandatory our your CPU will die
lol u guys I tried it without once on a Pentium and it was so cool I really didn't get it but with no O.Cing never got more the 60c
don't remember the brand of the cooler or the cpu but I sure I didn't hallucinated that :)
Well please don't do that to any modern CPU, ever
Having problems with your fresh Windows 10 install? PM Me!
Windows 10- Want To Disable Telemetry, Disable Cortana, Disable Windows Updates? Look at my guide HERE
LTT Beginners Guide  | Community Standards | TN&R Posting Guidelines
https://linustechtips.com/topic/327392-thermal-paste-cooling/#findComment-4446763
It would be nice to see though a real Comparison with numbers and all who is the best cooler thermal paste less just for the kicks and viewers not for real desktop application :)
now don't get me wrong I do recommend and encourage everybody to use the paste and know that it working
this post is just for knowledge about it and fun I guess   @Kherm @Wauthar @Megahurt @Ganz
https://linustechtips.com/topic/327392-thermal-paste-cooling/#findComment-4446802
