Hello everyone!
Lately, I've been fighting myself on the subject of which case to buy. The three cases in question are the Fractal Design Define R5, Corsair Air 540, and the Thermaltake Core V21 (I know it's MATX). I will be adding a Radiator in the future. If anyone wants to suggest anything else, the case should be no bigger than (22 X 15 X 23) (H X W X D) It needs to support ATX or MATX as well as support two 240mm radiators (Larger is better, but 240mm is the minimum).
Thanks a bunch in advanced!
BOINC Setup:
i5 7200U @ Stock
Core2Duo T6600 @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/326922-issue-with-case-picking/
From my experiences with it, avoid the R5, it's no-where near as good as it been made out to be (Or maybe I just got a bad case, who knows)
LTT's fastest Valley 970, slowest Valley Basic and Extreme HD scores
Desktop || CPU - i5 4690k || Motherboard - ASUS Gryphon Z97 || RAM - 16GB Kingston HyperX 1866MHz || GPU - Gigabyte G1 GTX 970 *Cough* 3.5GB || Case - Fractal Design Define R5 || HDD - Seagate Barracuda 160GB || PSU - Corsair AX760
https://linustechtips.com/topic/326922-issue-with-case-picking/#findComment-4440600
What was wrong with it?
BOINC Setup:
i5 7200U @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/326922-issue-with-case-picking/#findComment-4440788
Doesn't make the computer that much quieter, which I could live with, but the side panel doesn't seem to fit right with the bottom front of the case so it rattles, makes a horrible noise if it rests in the right position and when you push it there's about 1-2mm of travel. And the side panel catch isn't that good.
But it does have pretty good airflow, and the hard drive trays do a good job of dampening the noise from a HDD, and there's loads of room for cable management.
https://linustechtips.com/topic/326922-issue-with-case-picking/#findComment-4440868
I dont know if the h440 fits ur dimensions but the case looks awesome and has plenty room for rads
CPU-i5 4690k 4.4ghz @ 1.190V, MOBO-MSI z97 gaming 3, Cooler-hyper 212 evo, GPU- r9 290x asus directcuII (-37Mv), Storage-120gb v300(switching soon), 1tb caviar blue, CASE-Red/black h440, PSU-Antec TPC 650.
https://linustechtips.com/topic/326922-issue-with-case-picking/#findComment-4440923
My issue with the H440 is it chokes the fans and doesn't allow much airflow.
BOINC Setup:
i5 7200U @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/326922-issue-with-case-picking/#findComment-4440986
Tbf the airflow isnt so bad as to be detrimental, it looks awesome and it has 3 120's straight of the back to kinda make up for that problem.
https://linustechtips.com/topic/326922-issue-with-case-picking/#findComment-4441660
If you are considering the Air 540, consider the Thermaltake Core X9, or X2:
Core X9: http://www.newegg.com/Product/Product.aspx?Item=N82E16811133275(out of stock at the moment :( )
Core X2: http://www.newegg.com/Product/Product.aspx?Item=N82E16811133276
Dubs are better than subs
https://linustechtips.com/topic/326922-issue-with-case-picking/#findComment-4443850
