Hey i bought a r7 265x (http://www.sapphiretech.com/presentation/product/product_index.aspx?cid=1&gid=3&sgid=1226&pid=2201&lid=1)
and wanted to know how much i can overclock it?
my cpu is a fx 6300 dont know if that means much kinda new to overclocking since this is the first pc i built
thx for your help :)
https://linustechtips.com/topic/326866-r7-265x-overclock-help/
Welcome to the forum!
Best way to over clock is to get Msi Afterburner from their website and watch a few youtube videos on how to safely OC your card.
CPU:Intel i5-2400Mobo:ASUS Maximus IV Gene-ZRAM: 8GB G.Skill DDR3 1333MHzGPU: Sapphire R9 280x Tri-XCase Corsair Obsidian Series 350DPSU:EVGA 500w 80+ Certified
https://linustechtips.com/topic/326866-r7-265x-overclock-help/#findComment-4439964
THIS.
Use multiple sources of information, and do not just copy their results/numbers and expect it to work.
It's a trial and error type of process.
Afterwards,.....To test,.. use Uengine's Heaven or Valley (NOT furmark)
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/326866-r7-265x-overclock-help/#findComment-4439985
