My CPU voltage was downclocking before but now it just stays at 1.3v.
SpeedStep is still enabled, I have no clue what happened :P
https://linustechtips.com/topic/326459-cpu-voltage-wont-downclock/
Voltage doesn't down clock. It's not a frequency. That being said, if you explicitly set your voltage to a certain value, it won't lower even if your clocks lower.
I just realized that the voltage won't lower because the clock speed won't downclock but it randomly seems to be working sort of now.
Weird.
Weird.
What's your power setting in Windows?
High performance.
I adjusted my minimum processor state to 5% as I read somewhere to set it to that.
Should I keep it at 5%?
High performance.
Change it to Balanced.
