Webcam help (make it active?)
Go to solution Solved by APrettyCoolWalrus,
My old Windows 7 MSI laptop required me to press FN+F6 to activate the camera...or maybe it was just F6
Is this a webcam on a laptop or is it a USB one? If so what model is it?
It's on a laptop, the laptop is a Clevo P650SE. :)
Does it show up in the device manager?
i5 4670k, GTX 970, 12GB 1600, 120GB SSD, 240GB SDD, 1TB HDD, CM Storm Quickfire TK, G502, VG248QE, ATH M40x, Fractal R4
i5 4278U, Intel Iris Graphics, 8GB 1600, 128GB SSD, 2560x1600 IPS display, Mid-2014 Model
All the parts are here, just need to get customized cords to connect the motherboard to the front panel.
