Good afternoon friends, recently I bought a motherboard MSI Z97 Gaming 7 and want to make a SLI with 2 MSI GTX 560 Ti, 2 are the same model, differing only in that one is 2GB and the other only 1Gb. .. want to do this while waiting to gather more money and buy a GTX 980. I hope you can help clarify my doubt in that case.
post-194651-0-62606900-1426102745_thumb.
post-194651-0-16521500-1426102844_thumb.
https://linustechtips.com/topic/326337-recommendation-for-a-sli/
Not happening. You must have the same amount of VRAM on each card.
https://linustechtips.com/topic/326337-recommendation-for-a-sli/#findComment-4432501
why... such old cards..
i5-4690k @ 4.2GHz | Asus Radeon R9 290 DirectCU II | Hyper 212 EVO | ASRock Z97 Extreme3 | Corsair Vengeance 8GB 1866MHz, Corsair XMS 4GB | 850 EVO 250GB, random 1TB drive | Corsair 200R | EVGA SuperNOVA 750W | Rosewill RK-9000BR | Logitech G700s | Logitech G930 | ViewSonic VG2427wm, Dell S2209W, Dell S2009W
Dell Inspiron 3147
Latitude E5420, Samsung 840 EVO 250gb, 12gb RAM, 1600x900 display
Pentium G3258 @ 3.2GHz | WD Red 2TB x3 in RAID-Z, Crucial MX100 128GB(cache drive) | Fractal Design Node 304 | Gigabyte GA-H97N-WIFI | Crucial Ballistix Sport 8GB | EVGA 500B
HTC One M8 64GB, Droid Razr M
https://linustechtips.com/topic/326337-recommendation-for-a-sli/#findComment-4432502
Your SOL you can't SLI those cards due to the difference in memory.
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
https://linustechtips.com/topic/326337-recommendation-for-a-sli/#findComment-4432505
the SLI will work but only 1GB will be usable
You sure? Never heard of that working.
https://linustechtips.com/topic/326337-recommendation-for-a-sli/#findComment-4432511
i don't think so i think that SLI  work but only 1GB will be usable my mistake
https://forums.geforce.com/default/topic/469402/sli/faq-quot-will-these-two-cards-work-in-sli-quot-sli-what-works-with-what-/
Manners Maketh Man
https://linustechtips.com/topic/326337-recommendation-for-a-sli/#findComment-4432513
i thought it would work, but only as fast as the slowest card...so 1gb? correct me if im wrong.
you are correct only 1GB will be usable sorry my mistake
Manners Maketh Man
https://linustechtips.com/topic/326337-recommendation-for-a-sli/#findComment-4432528
As far as I know it still won't work as the cards need to have the same amount of VRAM no matter what.
|King Of The Lost|
https://linustechtips.com/topic/326337-recommendation-for-a-sli/#findComment-4432539
They have to have the same amount of Vram.
My Gaming PC
|| CPU: Intel i5 4690@4.3Ghz || GPU: Dual ASUS gtx 1080 Strix. || RAM: 16gb (4x4gb) Kingston HyperX Genesis 1600Mhz. || Motherboard: MSI Z97S Krait edition. || OS: Win10 Pro
________________________________________________________________
Trust me, Im an Engineer
https://linustechtips.com/topic/326337-recommendation-for-a-sli/#findComment-4432552
rip half the memory chips off the 2GB card pcb. otherwise I don't think it will work. Its worth trying them in both orientations just to be sure, but the Vram mismatching is a myth afaik. If it was me I would try (or try to find out if) flashing the bios of the 2GB card to only use 1GB, but who knows if that even works or has been done.
R9 3900XT | Tomahawk B550 | Ventus OC RTX 3090 | Photon 1050W | 32GB DDR4 | TUF GT501 Case | Vizio 4K 50'' HDR
https://linustechtips.com/topic/326337-recommendation-for-a-sli/#findComment-4432555
You are mixing SLI and Crossfire now.
My Gaming PC
https://linustechtips.com/topic/326337-recommendation-for-a-sli/#findComment-4432592
sorry my mistake it's useb to be the case
- All GPUs must have the same amount of VRAM and an identical Bus Width
-- You cannot use a "2GB" version with a "4GB" version or "3GB" version with a "6GB" version in SLI or a 1GB 192 bit bus with a 1GB 256 bit bus Etc.
Note: It used to be possible to enable SLI on cards with differing VRAM but this is no longer available.
Manners Maketh Man
https://linustechtips.com/topic/326337-recommendation-for-a-sli/#findComment-4432612
is that they are old already, but recently is that I'm updating my pc, and I bought this msi z97 gaming 7. 16 gb of ram and i7 4790k processor, not enough to buy the msi gtx 980, $ 200 .. I am missing . so I want to make it work with those 2 to see how they work, but wanted to know if that difference function having only memory
https://linustechtips.com/topic/326337-recommendation-for-a-sli/#findComment-4432670
As others have said above you cannot use those cards in a SLi config. Due to the mismatched VRAM.
You could try and flash a BIOS but that may not work.
https://linustechtips.com/topic/326337-recommendation-for-a-sli/#findComment-4432726
I do not do SLI, I will use only one while I wait to buy the gtx 980 or maybe buy me the 970 ... thank you very much.
https://linustechtips.com/topic/326337-recommendation-for-a-sli/#findComment-4432827
