GTX 970 cable?
Solved by Tim Drake,
I saw that Linus had to plug in a cable from GPU to motherboard on his GTX 670 TI (i think its that one, bu i might be wrong). I saw this on his 1500 pc build vid. Although, I am going to use an MSI GTX 970. Would I still need to plug it in with a chord? Doesnt it already work bu plugging it in the PCIE x16 port without the need to add an eight or six pin cable? Also what is the use for the 8 or 6 pin cable?
You will need to add a 6 and an 8 pin.
