In games, after about a minute of playing, my GPU usage will randomly drop from 85-100% to 50-60%. This causes a massive drop in FPS and makes some games unplayable. This does not just happen in 1 or 2 games. Every game that I have tried has this issue. I also just revived my GPU back from the manufacturer after sending it in for a completely different reason.
Considering that the drops might not have been an issue with the GPU, today I purchased a second Radeon HD 7950 to use in Crossfire with the one I already had. When I play games with Crossfire enabled, however, the GPU uage does not exceed 40%, giving me lower FPS than with just one card.
This is really bothering me and making me worry that I will have to spend even more money on completely new GPUs. Any help would be GREATLY appreciated.
Anything I've already tried:
-Reinstalling the drivers
-Removing GPU overclocks
Other System Specs:
GPU: Sapphire AMD Radeon HD 7950 (x2)
CPU: Intel Core i7-4790k (@ 4.6 Ghz)
RAM: 8 GB 1600 Mhz
Motherboard: Gigabyte Z97MX-Gaming 5
Power Supply: EVGA Supernova 850 B2
https://linustechtips.com/topic/325869-gpu-usage-randomly-dropping-please-help/
Temps? It could be thermal throttling
Planned I Hope Someday I Do First Build: CPU: Intel Core i7 5820k CPU Cooler: CM Hyper 212 EVO Mobo: MSI X99S SLI PLUS RAM: Corsair Vengeance LPX 16GB (4x4GB) DDR4-2133Mhz Storage: Corsair Force LS 240GB SSD & 2TB WD Green Graphics Card: ASUS GTX 970 4GB Turbo Case: NZXT S340 White PSU: EVGA SuperNOVA NEX 750W 80+ OS: Windows 8.1 64-bit OEM Monitor: AOC i2267Fw 60Hz 22" Monitor
