Hello, ladies and gentlemen. So, next week I'm doing a class at my school on computers. The hardware and how everything works, as well as the software and how all that works. I'm going to be using my old FM2+ system as a demonstration, as well as an old socket 939 system for hands on. I have prepared an outline so that I don't forget to mention anything. I was wondering if you guys could give it a look over and give some input. Also, I was wondering if anyone can give me a nice punny name. My Principal needs a name for the class for the sign-up sheets and I want something @LinusTech would be proud of. Thanks for the help guys.
CPU (Central Processing Unit):
  • Brain
  • Physical make-up of a CPU
  • Binary, on or off
  • Hz, transistors
  • Cores, hyper-threading
  • AMD/Intel
  • Sockets
  • APU/CPU
Motherboard
  • Nervous system
  • Layout of a mobo
  • Different types of ports and plugs
  • VRM (Voltage regulation module)
RAM (Random Access Memory)
  • Short-term memory
  • Types
  • Sizes
  • Frequency
  • Latency
PSU (Power Supply Unit)
  • Circulatory system
  • Sizes
  • Efficiency
  • Connectors
  • Modularity
GPU (Graphics processing unit)
  • Eyes
  • Similar to CPU, but more slower cores (CUDA/Stream)
  • PCI-E
  • AMD(ATI)/nVidia
  • Technologies (G-Sync/Freesync, Mantle/DX/OpenGL, Crossfire/SLI)
Case
  • Skeletal System
Cooling
  • Water/Air
  • Cable management
  • Fans (Sizes, brands, speeds, noise)
  • Thermal paste
  • Dust
  • Air paths
  • PWM/DC
Storage
  • Long-term memory
  • SSD/HDD
  • SAS/SATA/IDE
Peripherals
  • Appendages
  • Monitors (IPS/TN, response time, frequency, inputs)
  • Mouse (DPI, laser/optical)
  • Keyboards (Mechanical/membrane)
Software
  • OS (Windows, Linux, OSX)
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/325381-need-some-input/
I would say that the case is the skeletal system and the motherboard is the nervous system
That makes more sense. I'll change that.
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
https://linustechtips.com/topic/325381-need-some-input/#findComment-4419266
