http://pcpartpicker.com/p/QttyRB
Above is my ideal system build, take a look and tell me what's wrong and why I'm an idiot.
Includes peripherals, monitors, etc.
Price is not an issue, but i want to be reasonable.
The peripherals chosen are my preference (Mouse, Keyboard, Headset)
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/325141-ideal-build/
Seagate? Please go with WD Black.
Price per GB is nuts on those though
Solitaire.
https://linustechtips.com/topic/325141-ideal-build/#findComment-4416235
The Video card was the toughest choice, as there have been many controversies over the GTX 970, ideally i would do 3-way SLI 970s, but I'm being careful around them.
Solitaire.
https://linustechtips.com/topic/325141-ideal-build/#findComment-4416253
First, the CPU cooler.  its good, but if you can stretch the budget to get something better, Noctua is best (unless you hate the color, which is admittedly ugly)
Second, the sound card.  delete it.  Tests have shown there is no benefit to having a dedicated sound card.  If you want premium audio, get an external usb DAC/AMP.
Third, wifi? dude, go ethernet or go home.  Run new wires if you have to.  Wifi is for mobile devices!
i7 4790k @4.7 | GTX 1070 Strix | Z97 Sabertooth | 32GB  DDR3 2400 mhz | Intel 750 SSD | Define R5 | Corsair K70 | Steel Series Rival | XB271, 1440p, IPS, 165hz | 5.1 Surround
PC Build
Desk Build
https://linustechtips.com/topic/325141-ideal-build/#findComment-4416270
The cooler has been recommended to me many times, im not familiar with Noctua and personally, case doesn't have a window, so color doesn't matter
The WiFi and sound cards are just there for completions sake.
And OBVIOUSLY Ethernet is superior.
Solitaire.
https://linustechtips.com/topic/325141-ideal-build/#findComment-4416300
You're getting a 4790k and a superclocked 980 and you're complaining about WD Black what
I have SSDs for speed, the drives can be slow, especially if it will save me $200
Solitaire.
https://linustechtips.com/topic/325141-ideal-build/#findComment-4416310
The cm 212 is the king of value for after market cooling, but its not the king of performance.  for ultimate cooling performance (not including liquid) it's the Noctua.
PC Build
Desk Build
https://linustechtips.com/topic/325141-ideal-build/#findComment-4416333
Get a Noctua or Dark Rock and get rid of the wifi and sound card and get Asus RoG for that budget or BenQ pls plspls
I happen to have that Acer monitor now and really like it.
Solitaire.
https://linustechtips.com/topic/325141-ideal-build/#findComment-4416352
Two SSD and hard disk not required.
ummm, yeah.
Boot off 1 SSD
Game off the other
The 2 drives are for storage, if I record/edit footage I read from one and write to another
Solitaire.
https://linustechtips.com/topic/325141-ideal-build/#findComment-4416358
Solitaire.
https://linustechtips.com/topic/325141-ideal-build/#findComment-4416377
Here, I made a better build. V300 have performance of a hdd, if you want get a 3tb drive becouse it's cheaper than 2x2tb, also I would rather go for a 1 4k or 1 1440p screen, oh and you have only 2 ears so 7.1 headphones won't work quite well, ath-50x are good too
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($324.98 @ OutletPC)
CPU Cooler: Enermax ELC-LT240-HP 111.0 CFM Liquid CPU Cooler  ($105.24 @ Amazon)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($143.98 @ Newegg)
Video Card: Gigabyte GeForce GTX 980 4GB WINDFORCE Video Card  ($574.99 @ NCIX US)
Case: Corsair 750D ATX Full Tower Case  ($119.99 @ Micro Center)
Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($114.99 @ Micro Center)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($19.79 @ OutletPC)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($87.75 @ OutletPC)
Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter  ($36.76 @ OutletPC)
Monitor: BenQ GW2765HT 60Hz 27.0" Monitor  ($387.99 @ NCIX US)
Mouse: Razer DeathAdder Chroma Wired Optical Mouse  ($58.99 @ Amazon)
Headphones: Audio-Technica M50x Headphones  ($149.95 @ Amazon)
Total: $2726.72
Generated by PCPartPicker 2015-03-09 16:36 EDT-0400
https://linustechtips.com/topic/325141-ideal-build/#findComment-4416416
If you are going for an ideal build get a Kraken x61 instead of the Hyper EVO 212, the Hyper is great but if you are going for ideal get the kraken and oc... a lot. IC Diamond TIM and I would get an Asus RAMPAGE V EXTREME. That is if you really want the best. Everything else seems fine but I prefer the Gigabyte G1 Gaming GTX 980, that is just  my preference though.
Edit: I just realised that that mobo isn't compatible.
https://linustechtips.com/topic/325141-ideal-build/#findComment-4416734
Ok, first off get a NH U14s instead of an NHD15, they perform roughly the same.
Second of all, don't get corsair fans. They're not too bad as far as fans are concerned, but they're way overpriced for their cheapy plastic build.
Dont get a 5.25 dvd drive in an obsidian case, they're ugly as all hell. Just get an external USB one.
Don't get kingston SSDS!
They're cheap because they're utter shit! I cannot express this enough, they barely get 100 up and down
Other than that i would recommend a define R5 instead for the case, but thats more of a personal choice.
Specs: 4790k | Asus Z-97 Pro Wifi | MX100 512GB SSD | NZXT H440 Plastidipped Black | Dark Rock 3 CPU Cooler | MSI 290x Lightning | EVGA 850 G2 | 3x Noctua Industrial NF-F12's
Bought a powermac G5, expect a mod log sometime in 2015
Corsair is overrated, and Anime is ruined by the people who watch it
https://linustechtips.com/topic/325141-ideal-build/#findComment-4416775
Lookin pretty damn good I'd say.  I want this build!
I know I was the one to steer you toward the Noctua cooler, but if you want good looks, consider an AIO liquid cooler.  The Noctua is almost as good as liquid cooling but the thing is HUGE! which might be fine, but just be aware of it.
Others have commented on kingston SSDs, I'd look into it a bit, you don't want to be stuck with shitty SSDs.  They may be fine, but check review sites to be sure, and check amazon.com for average user reviews to get an idea of customer satisfaction.  The Samsung 850 EVO just came out and is a great choice, but more expensive.
PC Build
Desk Build
https://linustechtips.com/topic/325141-ideal-build/#findComment-4416887
I happen to be using a Kingston 240GB SSD right now, not having any issues.
Solitaire.
https://linustechtips.com/topic/325141-ideal-build/#findComment-4430495
