If any of you could please give me suggested changes on this build. http://pcpartpicker.com/p/yCrXpg
Budget is $500 could go to $600 but only if I'm getting something major for the extra hundred.
Also I already have a SSD, GTX 760, and 8GB's of ram for this PC and would like to use this case but if there is a slightly smaller one for the price I would consider it.
Thank You for your input.
https://linustechtips.com/topic/324408-mobile-build/
I'd go for the Silverstone SG05/06 if you're looking for small.
"Rawr XD"
https://linustechtips.com/topic/324408-mobile-build/#findComment-4406855
