Its good!
Get a modular PSU like a CXM Series or if you like silence then a RM series PSU form corsair.
Personally i like the Corsair 230T a lot. Its is also quite inexpensive :)
i5 4690k,GTX980,HyperX Savage 8gb,Asus sabertooth mark 2, samsung 850 evo and wd green 1tb with Corsair CSM 650M
https://linustechtips.com/topic/324400-my-first-built/#findComment-4406812
I see we have a Corsair fan here... sorry to break it to you, but no Corsair PSUs are good for the money.
"Rawr XD"
https://linustechtips.com/topic/324400-my-first-built/#findComment-4406864
Hey guys,
I'm thinking of building my first pc, is this a good built and what case should i use? http://pcpartpicker.com/p/XrPNTW
Thanks!
You're overspending on SSD and PSU. Here is a better build for the same price, with better SSD and PSU, as well as better motherboard and graphics card
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($222.75 @ OutletPC)
Motherboard: ASRock Fatal1ty Z97 Killer ATX LGA1150 Motherboard  ($103.98 @ Newegg)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE Video Card  ($349.99 @ Newegg)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  ($46.99 @ NCIX US)
Total: $926.57
Generated by PCPartPicker 2015-03-08 12:41 EDT-0400
"Rawr XD"
https://linustechtips.com/topic/324400-my-first-built/#findComment-4406878
Looks like a great machine to me.
Is it bad that my dream setup only costs a few thousand not counting the obutto?
CPU: FX-8320
Motherboard: asrock 970Pro3 r2.0
Memory: Team Zeus Blue 8GB DDR3-1600 Memory
Video Card: Sapphire Radeon R9 280 3GB DUAL-X Video Card
Case: Deepcool TESSERACT BF ATX Mid Tower Case
Power Supply: EVGA 500W 80+ Certified ATX Power Supply
SSD: MX100 128GB
HDD: WD 2TB black edition
https://linustechtips.com/topic/324400-my-first-built/#findComment-4406925
Total: $926.57
why the other Motherboard? and what case should i use with it?
https://linustechtips.com/topic/324400-my-first-built/#findComment-4407025
Around 50 $/€
Your choice really, but here's some good suggestions
Corsair 300R
http://pcpartpicker.com/part/corsair-case-300r
NZXT Source 220
http://pcpartpicker.com/part/nzxt-case-caso22001
Fractal Design Core 2300
http://pcpartpicker.com/part/fractal-design-case-fdcacore2300bl
Bitfenix Merc Alpha
http://pcpartpicker.com/part/bitfenix-case-bfcmrc100kkx1u3
"Rawr XD"
https://linustechtips.com/topic/324400-my-first-built/#findComment-4407066
Corsair 300R
NZXT Source 220
Bitfenix Merc Alpha
thanks! I think i"ll go with the corsair 300r
https://linustechtips.com/topic/324400-my-first-built/#findComment-4407158
Corsair 300R
NZXT Source 220
Bitfenix Merc Alpha
Here in the Netherlands this built gets a little bit more expensive than i like, it is more a 1000€ built than a 800€ one, do you know a good 800$/€ built?
https://linustechtips.com/topic/324400-my-first-built/#findComment-4407199
Pretty hard for 800 euro :o You can't get the build in the OP with that.
I overall have a budget of 1200/1300 euro's with everything included, mouse, keyboard, monitor and the os. Can maybe get some parts cheaper because of some family that is working in the it sector.
https://linustechtips.com/topic/324400-my-first-built/#findComment-4407997
Ahh like that.... yeah okay.
Still with 800 euro's I would try a 280X and i5 4670k, later upgrade the GPU, you don't have enough with 800
https://linustechtips.com/topic/324400-my-first-built/#findComment-4408024
