Best audio converter?
Go to solution Solved by -TesseracT-,
I use foobar2000 for converting music because of the wide range of supported codecs and speed (it can use all 8 cores of my 8320, which makes it a scenario in which it is an awesome processor). I have no idea if it is the best option though. I believe it's not really a converter too, it's just a GUI for CLI tools which it includes. Still nice, though.
http://www.foobar2000.org/components/view/foo_input_monkey
Pretty sure audacity, if not natively I'm sure there's a plugin or mod somewhere that allows it.
Benefits: Free
Even fi it doesn't, at least you haven't paid for anything.
Disadvantages: Might take a little time.
Intel i7 4790k | Corsair H110i GTX | MSI Z97S Krait | 16GB HyperX Fury | ASUS Strix GTX 970 | Samsung 850 EVO 120GB SSD | Seagate 1TB Hybrid SSHD | WD 3TB Green | Corsair TX750M |
Corsair Graphite 760t White | 3x AOC i2267Fwh 21.5 inch IPS Monitor 1080p | Corsair Raptor k50 RGB | Logitech G500 | Blue Snowball
https://linustechtips.com/topic/323014-best-audio-converter/#findComment-4390159
~non cogito, ergo non sum?~
https://linustechtips.com/topic/323014-best-audio-converter/#findComment-4390202
It doesn't support FLAC though, atleast without extensions. That's why I need to convert.
https://linustechtips.com/topic/323014-best-audio-converter/#findComment-4390214
https://linustechtips.com/topic/323014-best-audio-converter/#findComment-4390220
