It's been a long time since i built my last custom PC and it has served me for over a decade with 0 problems and only minor graphic card upgrades but I am way out of the loop now. I just created an account on here so I don't know if anyone can see my PC in my profile but I will list what I am planning below. Pretty much I want to know if this system looks good, how do you think it will handle 4k, and if there are any upgrades I would be better off going with. Any help would be much appreciated because it's time to retire the PC I built in 04'. Also if anyone could recommend a solid 4k monitor that'd be great!!!
Intel Core i7-4790K Haswell Quad-Core 4.0GHz LGA 1150 Desktop Processor Intel HD Graphics 4600 BX80646I74790K
ASUS MAXIMUS VII HERO LGA 1150 Intel Z97 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
EVGA 04G-P4-2983-KR GeForce GTX 980 4GB 256-Bit GDDR5 PCI Express 3.0 x16 SLI Support Video Card
EVGA 110-B2-0850-V1 850W ATX12V / EPS12V SLI Ready 80 PLUS BRONZE Certified SLI Ready CrossFire Ready Modular Power Supply
IN WIN GR one Black Black SECC Full Tower Computer Case ATX 12V/EPS Power Supply Compatible
Silicon Power S60 3K P/E Cycle Toggle MLC 2.5" 120GB 7mm SATA III 6Gb/s Internal Solid State Drive (SSD)
CORSAIR Vengeance Pro 16GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 Desktop Memory Model CMY16GX3M2A1866C9R (Red)
https://linustechtips.com/topic/322912-custom-build-advicecritiquehelp/
What would you recommend for a smoother fps in aaa titles? (as in what components would be best to change?)
You would want 2 x GTX 980's or 2 x R9 290X's for 4K. Even then if you get a game that is very demanding, you might be looking at 40FPS.
http://www.tweaktown.com/articles/6725/4k-showdown-asus-gtx-980-4gb-in-single-sli-3-way-sli-and-4-way-sli/index.html
