Does this look like a good cpu,mobo build?
Cpu: Fx 6300 3.3ghz
Motherboard:MSI 970A-G46 AM3+ ATX
Just some minor gaming and maybe some video editing...D
Life is pain. Anyone who says any different is either selling something or the government.
----CPU: FX-6300 @ 4.2ghz----COOLER: Hyper 212 EVO----MOBO: MSI 970A-G46----PSU: OCZ 600watt----CASE: Black Corsair C70----GPU: Sapphire 7870 dual fan ghz edtion----2 random HDD'S----A couple fans here and there. Mouse: Gigabyte M6900-------Keyboard: Logitech G105-----Mousepad: Steel series something something.
https://linustechtips.com/topic/3227-build-help/
It looks good. What's the budget?
Asrock 890GX Extreme 3 - AMD Phenom II X4 955 @3.50GHz - Arctic Cooling Freezer XTREME Rev.2 - 4GB Kingston HyperX - AMD Radeon HD7850 - Kingston V300 240GB - Samsung Spinpoint F3 1TB - Chieftec APS-750 - Cooler Master HAF912 PLUS
osu! profile
https://linustechtips.com/topic/3227-build-help/#findComment-41208
Well About 190-200 for mobo,cpu,ram. Low I know but its all I got.If I get it.
https://linustechtips.com/topic/3227-build-help/#findComment-41213
Since the RAM is about 30-40$, that leaves 160$ for the CPU+Mobo. For that price the A10 5800K might be a better choice.
osu! profile
https://linustechtips.com/topic/3227-build-help/#findComment-41224
Ye I would like that 1 but the only reason I can get a cpu+,mobo for that price(with the mobo I want) Is in a bundle...and that 1 is not an option....
https://linustechtips.com/topic/3227-build-help/#findComment-41243
If you can get it and it's in the budget, why not. It's not a bad CPU and the board doesn't look bad.
osu! profile
https://linustechtips.com/topic/3227-build-help/#findComment-41299
