So last night I reinstalled windows (8.1) because I was getting bsods preventing me from getting to the login screen.  Today I reinstalled all my steam games and programs and stuff, and was causally web browsing when I got a random bsod, saying "system_thread_exception_not_handled".  I looked it up and apparently this can be caused by an overload of data or missing system files.  This does not make sense to me as my drive is no more than half full with another, completely empty 1tb drive accompanying it, and I just reinstalled windows.  Should I be worried?  The PC seems to be working fine now but if there's a fix or something I can do to prevent this that would great.  Thanks  :D
My life is consumed by CS:GO, even though I'm not exceptionally good at it.
CPU: AMD A10-5800K | GPU: Gigabyte R9 270 2GB | RAM: 8GB 1333Mhz HyperX Blu | Storage: 120GB Samsung 850 EVO + 1TB WD Caviar Blue | Chassis: NZXT H230 | Mobo: Gigabyte GA-F2A88XM-HD3 | PSU: Corsair CX500 500W | Cooling: CM Hyper 212 EVO | OS: Windows 10
In order of priority: GTX 970 Strix, 2 good 1080p monitors, i5 4690k, MSI Z97 Gaming 5 LGA 1150, a job
https://linustechtips.com/topic/322637-bsod-system_thread_exception_not_handled/
This error is ALMOST COMPLETLY memory or storage related.  Occasionally it will be driver related.
What does event viewer say?
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
event viewer?  can you tell me how to do that pls (sorry complete noob)
Yea, you can do it that way.  Or just search "Event Viewer" or "View Event" (depending on your version of Windows) and open it up.  IT DOES TAKE ABOUT 30 SECONDS OR MORE TO GET ALL THE RECORDS PULLED UP.
What we're looking for is anything within the past 24 hours.
Mine looks like this.  All you got to do is find the error and double click on it and it will give you some info.
post-4855-0-89802600-1425592291_thumb.pn
Well the most recent one is as follows:
"Warning:  The driver \Driver\WudfRd failed to load for the device SWD\SensorsAndLocationEnum\LPSensorSWDevice"
there is a critical one a bit father but all that says is just "the system reboot was unexpected, could be caused by a crash, etc."
This is a problem with drivers.  This specific one is a fingerprint reader it looks like.
wat
I have no idea what this driver is or how to fix it
WHATEVER YOU DO, every single little error is NOT solvable.  Do NOT go around thinking you can "fix" all of them.  Some just happen because they do.
What you want to look for is errors that occurred at the time of failure.
The question isn't necessarly this exact driver.  The question is which error is causing issues.
well, the driver failing to load error happened last night, and the critical happened about 20 min ago, which I assume was the bsod because that was around when it happened.  Other that that it's just "information" before the critical from today.
Save the "Administrative Events" log and either post it, or send it to me
https://technet.microsoft.com/en-us/library/cc749339.aspx
here are my system events, under "windows logs"
events.txt
The Windows Logs isn't going to help. That wont have any critical data in it.
Plus, I need it in a format I can view in event viewer. Text format is simply too tedious to go through for free like this, lol.
How should I get to administrative events then?
here we go, it's in xml as LTT woun't let me upload evtx.
events.xml
Did you not read the link from before? It gives you instructions...
All you have to do (simply) is right click it and "save the custom events as"
LTT won't let me upload evtx or csv, I've put up the txt and xml versions
here it is in txt
events1.txt
Says its corrupted. Can you just save it as a .evtx and then change the file name to whatever (.doc would be easy) then upload it and Ill change it back when I get it...
Got to love dem loop holes
k, here
save1.doc
There isn't anything crazy wrong except it looks like you got a bunch of software conflicts. I have noticed you didn't install your drivers, you let Windows find them and download the generic ones, but that is whatever. I personally think you need to reinstall Windows and do it completely right without taking the lazy way out :P
You got 2 driver issues though since your last reboot at 4:25.
One is a driver not loading at all, and the other is where all the services aren't installed.
