This is my first water cooling build. I figured i would go all out if i was going to do it. Learned a ton during this build, that is for sure.
Specs:
Asus Formula VII
Intel 4790K
Dominator Platinum 2400 16G
Place holder graphics cards--> 2x 660TI FTW
(waiting for Titan X release and its water block)
All EK waterblocks
2xD5 pumps with Bitspower Resevoirs with pump mods
Bitspower and Monsoon chain gun fittings
Nexxos UT60 480 Radiator- Push/Pull with Corsair Static pressure fans - CPU
Nexxos XT45 560 Radiator- Push/Pull with Noctua Static Pressure fans - GPU
EVGA 1000W Platinum power supply
Case Labs SMA8 with 4 Corsair Air pressure fans
All Hardline tubing, absolutely no flex tubes even in the basement.
1 125G SSD - OS
2x 250G SSDs in Raid 0 - Games
1x 1TB 7200 HD - Back up/random crap/music
I am wondering if I should use a different color coolant for the GPU loop. I was thinking of using Mayhems Pastel UV Red, possibly renaming the project Crimson Toxicity if i do. Any thoughts/suggestions would be greatly appreciated!
http://imgur.com/jKfM4kK
http://imgur.com/Rwjr1AR
http://imgur.com/kuInlrz
http://imgur.com/DbOWNXIhttp://imgur.com/XH6r640
http://imgur.com/ye7SaCc
http://imgur.com/2ZiIHRW
http://imgur.com/mT5B0cb
http://imgur.com/rXwyokB
Thanks Linus Tech Tips!  Without your youtube channel and many other personalities (like Jayz 2 cents, PCJunkie Mods) i would not have been inspired to become an enthusiast water cooler, even though im a beginner through you all I have learned enough to get me by.
https://linustechtips.com/topic/322536-project-hydro-toxicity/
Keep me updated :) This sounds awesome!
ALCATRAZ |   CPU: i9 9900k @ 5GHz, Motherboard: Asus Prime Z390-A, RAM: Corsair Vengence LPX 32GB, GPU: Gigabyte 1070Ti Case: Zalman MS800 Plus, Storage: Corsair 2TB NVME | Crucial M550 128GB SSD  |  WD 640GB HDD, PSU: XFX Pro Series 1050w, Display: ASUS MG279Q, Cooling: Noctua NH-D15
https://linustechtips.com/topic/322536-project-hydro-toxicity/#findComment-4383893
Really?  You don't think the Titan X will run Run games like Star Citizen more efficiently than 2 980s?
Eventually i plan on putting a second Titan X when I get back to the states.
Nope. Two 980s is about 1100 USD... ONE titan X is going to be $1000 (or more)... and only slightly better performance.
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
https://linustechtips.com/topic/322536-project-hydro-toxicity/#findComment-4383918
