I want to buy this: http://www.overclockers.co.uk/showproduct.php?prodid=MO-113-BQ
But, I currently have an AMD R9 295x which only supports Mini Display port. BenQ monitor only has Display Port connection. Would I need to buy a special adapter/cable that is 1.2a or will 1.2 work cable work with FreeSync?
Would either of these work with FreeSync?
http://www.overclockers.co.uk/showproduct.php?prodid=CB-000-CG&emcs0=2&emcs1=Produktdetailseite&emcs2=CB-018-CG&emcs3=CB-000-CG
https://linustechtips.com/topic/322444-amd-freesync-cable-compatibility/
I don't believe it matters what cable you use... As long as the port on both ends are 1.2A.
Is it bad that my dream setup only costs a few thousand not counting the obutto?
CPU: FX-8320
Motherboard: asrock 970Pro3 r2.0
Memory: Team Zeus Blue 8GB DDR3-1600 Memory
Video Card: Sapphire Radeon R9 280 3GB DUAL-X Video Card
Case: Deepcool TESSERACT BF ATX Mid Tower Case
Power Supply: EVGA 500W 80+ Certified ATX Power Supply
SSD: MX100 128GB
HDD: WD 2TB black edition
Ports on both ends as in on graphic cards and monitor?
yea
CPU: FX-8320
SSD: MX100 128GB
