Borderlands 2 low FPS
Go to solution Solved by Noveria,
Ok, so i have found the problem and a solution.
The config file 'WillowEngine.ini' that controls all the graphical settings for the game had different values to my Borderlands 2 one.
The Pre-Sequel one had things like Dynamic Lighting, bloom, motion blur, fog and lens flares set to false. (off) so the game was in fact not running on the same settings as 2
I have now copied the Pre-Sequel 'WillowEngine.ini' into the Borderlands 2 config files over writing the previous one and now have the expect frame rates.
Here is a link to the modified 'WillowEngine.ini' for improved frame rate if anyone is interested:
http://www.mediafire.com/view/18fg2220raachcv/WillowEngine.ini
Make sure if you use this file that it is set to read only when the game is running!
To change in game settings such as view distance or texture quality you must do this every time you launch the game, or find the appropriate settings in the .ini file and edit them manually.
To edit it them manually you must close the game, right click, properties, uncheck read only, then open and search within the file. Once done save and remember to make read only again.
Thank you all for your help and suggestions.  :)
I have both a copy of Borderlands 2 and Borderlands The Pre-Sequel installed, however Borderlands 2 gets significantly lower frame rate.
I revive approximately a stable 70 fps whilst playing The Pre-Sequel, but with Borderlands 2 barely able to have a stable 30 fps, on exactly the same in game settings?
Both are set to High in Task Manager and are defiantly running off my Nvidia GPU and not the Intel one also in my laptop
I do not have Nvidia Ge force Experience installed , nor is Nvidia PhysX.
(I uninstalled both to see if it would resolve the issue with no change).
My system specs meet recommend and I'm able to play Pre-Sequel comfortably on Max +60fps (minus PhysX)
I have tried a clean install of Borderlands 2 as well, as a previous version (no difference)
I've deleted the .ini files located in MyDocuments/My Games/Borderlands2 and run the game (wich replaced them) with no change
Tried allocation more memory to Borderlands 2 using one of the .ini files with no change
In-Game settings (for both games):
Mode: Full Screen
Resolution: 1336x768 (native)
V Sync: Off
Frame rate: Unlimited
Anisotropic filter: 16x
Bullet Decal: High
Foliage Distance: Far
Texture Quality: High
Game Detail: High
Ambient Occlusion: On
Depth of Field: On
FXAA: Off
View Distance: Ultra High
PhysX Effects: Low
Textue Fade: Off
Colorblind Mode: Off
System Specs:
Laptop: ASUS K53SV
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601)
GPU: NVIDIA GeForce GT 540M (347.52) driver
CPU: Intel® Core i5-2430M CPU @ 2.40GHz (4 CPUs)
Ram: 4096MB
DirectX: 11
NVIDIA Control Panel settings:
Preferred graphics processor: High-performance NVIDIA processor
Use global setting (High-performance NVIDIA processor)
Ambient Occlusion: Quality
Anisotropic filtering: Application-controlled
Antialiasing - FXAA: Off
​Antialiasing - Gamma correction: On
​Antialiasing - Mode: Application-controlled
​Antialiasing - Setting: Application-controlled
​Antialiasing - Transparency: Off
CUDA - GPUs: All
Maximum pre-rendered frames: Use the 3D application setting
Multi-display/mixed-GPU acceleration: Multiple display performance mode
Power management mode: Prefer maximum performance
Shader Cache: On
Texture filtering - Anisotropic sample ooptimization: Off
Texture filtering - Negative LOD bias: Allow
Texture filtering - Quality: Quality
Texture filtering - Trilinear optimization: On
Threaded optimization: Auto
Triple buffering: Off
Vertical sync: Off
Virtual Reality pre-rendered frames: 1
Game Versions:
Borderlands 2: v1.8.2
Borderlands Pre-Sequel: v1.0.1
https://linustechtips.com/topic/322301-borderlands-2-low-fps/
i think 30+fps is completely stable and varies only 1 or 2 fps then its good
its better to have 30fps which is stable that 60 fps which is not stable
there is nothing wrong with the settings i think the game is not optimized for phyx
i have a 60hz screen and should be able to run at +60 fps with my current settings and specs. Im not really ok with the 30fps it runs at, at the moment if i should be able to reach 60+. Like with The Pre-Sequel
https://linustechtips.com/topic/322301-borderlands-2-low-fps/#findComment-4380716
U WOT m8 ???? Physx run pretty good in Borderlands.
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
https://linustechtips.com/topic/322301-borderlands-2-low-fps/#findComment-4380730
Does it go up at all? Or go down?
What about indoors?
Have you tried starting one game then right after starting the next?
Have you looked at temps? Thermal throttling maybe?
https://linustechtips.com/topic/322301-borderlands-2-low-fps/#findComment-4380734
What about indoors?
cpu temp aprox 78C peeking around 83C
gpu temp aprox 68C
Pre sequel changes between 65-90fps depending on where / what is going on in the game
 2 between 25-50
with simular temps run directly one after the other
https://linustechtips.com/topic/322301-borderlands-2-low-fps/#findComment-4380829
cpu temp around 75C
gpu temp around 67C
 2 between 25-50
What happens if you turn all the graphics settings to low/off on borderlands 2?
https://linustechtips.com/topic/322301-borderlands-2-low-fps/#findComment-4380832
40-65 fps on minimal settings with 1280x720 resolution
with borderlands 2 the fps can drops down to around 10 for a split second or two when in combat but this isn't very frequent
i didn't notice as many fps drops on Pre-Sequel it very rarely drops to around 50 and this is only very briefly
https://linustechtips.com/topic/322301-borderlands-2-low-fps/#findComment-4380948
https://linustechtips.com/topic/322301-borderlands-2-low-fps/#findComment-4381335
Ah that sounds about right, Config file just wasn't saving with your changes.
Didn't you notice when it got... shitty? xD
https://linustechtips.com/topic/322301-borderlands-2-low-fps/#findComment-4382502
