Air flow or Static
Go to solution Solved by Tim Drake,
Airflow for case fans
Static Pressure for radiators/heatsinks
That's my opinion anyway.
Hi!
I want to put an exhaust fan, should i put a static pressure or an air flow
(The case by default had a static pressure for exhaust)
Thanks!
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/321614-air-flow-or-static/
If it's unrestricted you will get more performance out of an airflow fan but as a rule you should always buy a static pressure fan as they are more versitile and perform better across the board.
"The of and to a in is I that it for you was with on as have but be they"
https://linustechtips.com/topic/321614-air-flow-or-static/#findComment-4371584
this is not Linus but this is the best video i have seen
if you don't want to watch the video
static pressure pushes air through at a higher pressure
airflow pushes more air in at lower pressure
Project Iridium:   CPU: Intel 4820K   CPU Cooler: Custom Loop  Motherboard: Asus Rampage IV Black Edition   RAM: Avexir Blitz  Storage: Samsung 840 EVO 250GB SSD and Seagate Barracuda 3TB HDD   GPU: Asus 780 6GB Strix   Case: IN WIN 909   PSU: Corsair RM1000      Project Iridium build log http://linustechtips.com/main/topic/451088-project-iridium-build-log/
https://linustechtips.com/topic/321614-air-flow-or-static/#findComment-4371622
https://linustechtips.com/topic/321614-air-flow-or-static/#findComment-4371675
