I was planning on building a new itx formfactor PC for Lan party's or when friends wanna come over and play some games (so that they don't have to bring there own PC).
I already have some parts but need your help for the other parts.
The parts that I already have:
-Sapphire HD 6950
-8 gig DDR3 Samsung RAM
-600 watt PSU with 80 plus
-1TB Seagte HDD
-120 gig HyperX fury SSD
So the only parts I need to complete the build are CPU, motherboard and case. And the budget is €250~€300. What would you Guys recommend?
(Motherboard has to have 7.1 sound card)
(Sorry for bad english, I'm Dutch)
https://linustechtips.com/topic/321533-budget-pc-build-need-help/
CPU: Intel Core i3-4150 3.5GHz Dual-Core Processor  (€116.80 @ Amazon Deutschland)
Motherboard: MSI Z97I AC Mini ITX LGA1150 Motherboard  (€115.89 @ Amazon Deutschland)
Case: Corsair 250D Mini ITX Tower Case  (€86.74 @ Amazon Deutschland)
Total: €319.43
Generated by PCPartPicker 2015-03-04 09:54 CET+0100
a little bit on the high side but it should do the trick
i3 core now
but later jump to higher CPU and the Z97 board supports OC of the future i7 CPUs
250D Corsair case is pricey but you cant fault the looks and features
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
Total: €319.43
i3 core now
I'm not really looking into upgrading this system in the future.
Maybe these parts?
-Pentium G3258 ~ €70
-MSI Z87I AC Gaming ~€107
-Corsair Obisidian 250D ~€93
I got my prices from Alternate.nl
Maybe these parts?
it could work
but note that Z87 boards may need BIOS updates to get them to accept G3258 which are Haswell Refresh CPUs
How about this one?
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  (€67.90 @ Caseking)
Motherboard: MSI Z97I Gaming AC Mini ITX LGA1150 Motherboard  (€139.43 @ Amazon Deutschland)
Case: Fractal Design Node 304 (White) Mini ITX Tower Case  (€81.56 @ Amazon Deutschland)
Total: €288.89
Generated by PCPartPicker 2015-03-04 11:38 CET+0100
How about this one?
Total: €288.89
The z97i gaming AC is €160 in the Netherlands so thats somewhat to expensive. Node 304 is a nice case aswell.
Try Gigabyte's Z97N Gaming 5 motherboard. I can't seem to find any more Z97 Itx boards that has 7.1 audio except for the gaming grade motherboards.
I kinda like the Node 304 than the 250D. I'm not saying the 250D looks bad but IMO it looks big for an itx case (maybe because of the feet) but meh it depends on your choice.
The gigabyte board is alsof very expensive (€180), but I don't mind going with z87, MSI's site says that the z87i gaming AC supports the Pentium out of the box. I alsof have an i5 4690k with an MSI z87-G65 board in my main PC and that also didn't need any updates to get the CPU to work.
Why you don't go to tweakers.net my Dutchie friend?
Here is the Mobo and if you need a cheaper one click here €92,85/€69,85
An I5 4460 (Good gaming CPU) €186,90
And the case €35,90
Prizes are form Alternate Netherlands
I need an ITX board and 7.1 sound for my speaker setup. But I will take a look on Tweakers ;-)
I think you can overclock even with H motherboard, but I'm not sure
I'm not sure if all H motherboards supports overclocking. All I know is that ASUS is the only one that can overclock the G3258 on non Z motherboards
and @Aapje98 as long as you have a z motherboard then that's okay. (check BIOS updates first, I'm a little hesitant with Z87 boards that can unlock the G3258 right out of the box
