Fan software controller
Go to solution Solved by thekeemo,
Speedfan
Hey guys, so i upgraded my case which came with 3 fans. My motherboard allows two plugged in and i was wondering, whats the best way to set the speed software wise?
PC: AMD Ryzen 7 5800X Gigabyte X570 UD Corsair Vengence 32gb 3200MHZ Gigabyte RTX 2070 Intel 512gb boot / Seagate 2tb spinner Windows 10 Corsair 4000D black
Fyi i am Autistic (Aspergers) so sorry for any social mistakes (im mostly okay) If you want to learn more, Just ask!
https://linustechtips.com/topic/320716-fan-software-controller/
Mkay that solves my problem :) thanks.
https://linustechtips.com/topic/320716-fan-software-controller/#findComment-4359221
