So I ahve a problem where all the fans in my case are spinning 100% all the time except gpu fans. I have haf 912+ case and 2 stock fans in it, 200mm front and 120mm rear and Mugen 2 rev b. cooler with stock fan, and the fan on the cooler is really loud at 100% and it is really annoying when it's spinning like that all the time. I don't mind it when I'm gaming but I would like my pc to be a little quiter when I'm surfing or watching movies. Is there any good free fan controling software?
https://linustechtips.com/topic/32056-fan-control-software/
Use MSI Afterburner to create a fan curve.
| CPU: INTEL i5 6600k @ 4.6Ghz @ 1.328v | Motherboard: ASUS Z170-AR | Ram: G.SKILL 2x8GB 2400Mhz | CPU Cooler : Corsair H100i V2
| GPU: GIGABYTE GTX980Ti G1 GAMING | SSD: SAMSUNG 840 EVO 250GB  Storage: WD 1TB GREEN | OS: Windows 10 Pro 64bit | PSU: FSP 650W AURUM S |
<<<<< BLK-Phant0m >>>>>
https://linustechtips.com/topic/32056-fan-control-software/#findComment-410654
Speedfan if your fans are connected to the motherboard.
So question, does speedfan work with the 3 pin headers/fans??
<p>Mobo - Asus P9X79 LE ----------- CPU - I7 4930K @ 4.4GHz ------ COOLER - Custom Loop ---------- GPU - R9 290X Crossfire ---------- Ram - 8GB Corsair Vengence Pro @ 1866 --- SSD - Samsung 840 Pro 128GB ------ PSU - Corsair AX 860i ----- Case - Corsair 900D
https://linustechtips.com/topic/32056-fan-control-software/#findComment-411646
