Hello
I recently posted a blog entry about my upcoming PC build. I also briefly asked people to tell me if they noticed any issues with the components, but I
though I'd post the parts list here just to be sure :) This is ultimately just the blog post without the "update" element.
Parts
Case:
Antec NSK3100
PSU:
350W CORSAIR VS Series
(Optical Drive):
LG GH24NS SATA Black - Bulk
RAM:
CORSAIR Value Select DDR3 1333MHz - 4 GB Kit
GPU:
Asus GeForce GT 610 Silent 2GB
Motherboard:
Asus A58M-E
APU:
AMD A4-Series A4-5300
Drive(s):
WD Green 1TB HDD
So there you go. Please tell me if you would recommend any components or changes (even compatibility issues), also remember that I'm aiming for a reasonably cheap build.
Thanks
"The FPS I got was this big!"
https://linustechtips.com/topic/320270-pc-build-components/
Oh yes, please remember that this build will most likely be used for low end gaming (with a $400 budget at most). More details on my peripherals on my profile.
Here. This should destroy your build. If you can't afford those extra 4$, there's a 250gb HD for 21$, instead of the 320gb for 30$.
CPU: Intel Core i3-4130 3.4GHz Dual-Core Processor  ($104.95 @ SuperBiiz)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($44.85 @ OutletPC)
Memory: PNY XLR8 8GB (1 x 8GB) DDR3-1600 Memory  ($52.25 @ Amazon)
Video Card: HIS Radeon R7 260X 1GB Video Card  ($109.99 @ Amazon)
Case: HEC Vigilance MicroATX Mini Tower Case  ($23.99 @ SuperBiiz)
Power Supply: EVGA 430W 80+ Certified ATX Power Supply  ($33.99 @ SuperBiiz)
Total: $404.01
Generated by PCPartPicker 2015-03-02 05:28 EST-0500
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/320270-pc-build-components/#findComment-4353205
Total: $404.01
Cool stuff, thanks.
https://linustechtips.com/topic/320270-pc-build-components/#findComment-4353212
