OK this is the updated version - http://ca.pcpartpicker.com/p/rYdFyc
I made the case black and the memory red to match the colour scheme
That board is more expensive than the one you replaced. You might as well stick with the 1st spec as it is cheaper, for the same performance.
Drop the WD Black and just get a normal Blue drive.
https://linustechtips.com/topic/320088-build-help/#findComment-4350443
Anything else I can do?
If you are willing to change the color scheme you could go with ASRock H97 PRO4 ATX LGA1150 Motherboard and G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory. It will save a bit more.
BTW, the gpu is out of stock at the lowest cost merchant.
https://linustechtips.com/topic/320088-build-help/#findComment-4350471
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  ($222.98 @ Newegg Canada)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($37.10 @ DirectCanada)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard  ($100.44 @ DirectCanada)
Memory: Crucial Ballistix Sport XT 8GB (2 x 4GB) DDR3-1600 Memory  ($64.99 @ Amazon Canada)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($59.95 @ Vuugo)
Video Card: Sapphire Radeon R9 280X 3GB Dual-X Video Card  ($300.34 @ TigerDirect Canada)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($89.99 @ Memory Express)
Power Supply: Corsair Builder 500W 80+ Bronze Certified ATX Power Supply  ($64.98 @ DirectCanada)
Total: $940.77
Generated by PCPartPicker 2015-03-01 20:51 EST-0500
I did change the 4430 for the 4440 because well for 1$ more it's worth it I also changed the ram for a cheaper model and I changed the hdd for a cheaper one. I also changed the motherboard as you were going a little overkill on it
https://linustechtips.com/topic/320088-build-help/#findComment-4350551
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($199.99 @ Micro Center)
Motherboard: Gigabyte GA-Z97-HD3 ATX LGA1150 Motherboard  ($82.98 @ Newegg)
Video Card: Sapphire Radeon R9 280X 3GB Dual-X Video Card  ($261.99 @ SuperBiiz)
Case: NZXT S340 (White) ATX Mid Tower Case  ($67.99 @ SuperBiiz)
Total: $803.79
Generated by PCPartPicker 2015-03-01 20:59 EST-0500
https://linustechtips.com/topic/320088-build-help/#findComment-4350625
I think the cooler is worth it, as it's only like $40. I like the case so I'm keeping that. So do you guys think that it's a good build? This should be able to get at least 50 fps on 1080p max settings in most games right?
If you get a really demanding game then you might have to slightly tone things down. The link below gives you a rough idea of FPS on a few different games.
http://www.anandtech.com/bench/product/1041
https://linustechtips.com/topic/320088-build-help/#findComment-4350771
