I think the cooler is worth it, as it's only like $40. I like the case so I'm keeping that. So do you guys think that it's a good build? This should be able to get at least 50 fps on 1080p max settings in most games right?
Yes. Yes, in most titles.
Do you guys think I should add an SSD? And if so, what is a good SSD that's not too expensive?
Yes. Minimum Sandisk SDSSDHP-128G-G25. Recommended OCZ ARC100-25SAT3-240G.
Also, do you guys think case fans are necessary?
I doubt you would need more than the ones that come with the case.
https://linustechtips.com/topic/320088-build-help/page/2/#findComment-4350853
Should I get a PSU with more watts for future upgrades and maybe some overclocking? PC Part Picker estimates the wattage at 448W and my PSU is 500W
You can get this 750W psu for $79.99 after rebate, if you want something bigger.
http://ca.pcpartpicker.com/part/evga-power-supply-110b20750vr
https://linustechtips.com/topic/320088-build-help/page/2/#findComment-4355135
