Problems with my server pc
Go to solution Solved by Starelementpoke,
K then, the most probable reasons are the os upgrade, or the hard drive then. I'd suggest trying to switch back to windows 7(easier to run most likely) or that the hard drive has been used too long and its too old.(its 160gb, im 99% sure those arent created today). Id suggest upgrading the hard drive to a new terribyte drive plus an ssd for the os.
Hello,
So like it's written on the topic title , I have some problems related to hosting minecraft/planet explorer server since they are running pretty slow. I have a ASUS RT-AC68U router with the server and my laptop connected.
The windows was reinstalled some days ago since I was thinking that there was any kind of bug or virus that affected it badly but it wasn't.
The CPUs aren't overheating even with these coolers (couldn't find any stock cooler for these)
The server pc is running Windows Server 2012 R2 Standard which is pretty useful but slow...
The specs are these :
Supermicro H8DME-2-LS006
2x AMD Opteron 2427 Six-Cores
16x 2GB DDR2 ECC Registered
Western Digital 160gb sata
430W PSU Thermaltake
The original power supply was removed since it broke , so i had a non-server standard psu.
Is there anything that could affect performance in any way or any upgrade possible?
https://linustechtips.com/topic/319387-problems-with-my-server-pc/
The servers are hosted via a batch file like the main server is using this :
"C:\Program Files\Java\jdk1.8.0_31\jre\bin\java.exe" -server -XX:+UseConcMarkSweepGC -XX:+UseParNewGC -XX:+CMSIncrementalPacing -XX:ParallelGCThreads=11 -XX:+AggressiveOpts -Xms2G -Xmx4G -jar cauldron-1.7.10-1.1236.05.212-server.jar nogui
So not really , i'm not using programs for hosting
