Pump question (which way does it flow?
Go to solution Solved by 79wjd,
In the middle, out the top
I know its probably a stupid question..
Im looking at the Swiftech MCP655 G1/4 Threaded Special Edition 12 VDC D5 Pump With Speed Controller.
http://www.performance-pcs.com/swiftech-mcp655-special-edition-12-vdc-d5-pump-with-speed-controller.html#You-May-Also-Be-Interested
Which ways does the water flow? i can seem to find it online and i need to know as it determains my fittings.
GPU: EVGA GeForce GTX 980 4GB Superclocked ACX 2.0 @1500mhz + 8000Mhz CPU: Intel Core i7 6700k Delided and Overclocked @4.8  MB: ASUS MAXIMUS VIII IMPACT  RAM: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory CPU Cooler: Corsair HG10+ H90 +H90 CASE: Corsair 380T  Storage: 120GB Samsung Evo SSD + Crucail 256GB Mx100 + 2TB Seagate/  OS: Windows 10 64bit Power supply:  Corsair RM750
https://linustechtips.com/topic/319205-pump-question-which-way-does-it-flow/
water goes in the front of the big circle and comes out the side
PSU Tier List | CoC
Gaming Build | FreeNAS Server
bottom is intake, top exhuast i believe
Thanks for the quick reply everyone, sorry couldn't select all of you for the answer
