USB TV Tuner?
Go to solution Solved by NeatSquidYT,
I'd get the Hauppauge one as they're a reliable brand. I don't think it matters too much as long as you don't go all cheapo (like 5 bucks)
The college i'm going to has access to cable for all rooms, but theres no room for a TV and my computer. I was wondering if anyone here on the LTT Forums had any experience with USB TV Tuners, if so could you recommend one? Thanks!
[Edit: I didn't think to mention I live the USA and need one that works with our cable providers.]
These two caught my eye while browsing around.
http://www.amazon.com/Kworld-Tuner-Tuners-Capture-UB435-Q/dp/B001LQEEEA/ref=pd_sim_pc_3?ie=UTF8&refRID=0829EG546MVZWDWKWG9K
http://www.amazon.com/Hauppauge-1191-WinTV-HVR-950Q-Hi-Speed-Connection/dp/B00BZYJ61E/ref=sr_1_9?s=electronics&ie=UTF8&qid=1424733677&sr=1-9&keywords=usb+computer+tv+tuner
Lord of Helium.
https://linustechtips.com/topic/319109-usb-tv-tuner/
I's about to say this, so rather than sounding like a broken record, just take that ^ comment and duplicate it twice. ;)
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
https://linustechtips.com/topic/319109-usb-tv-tuner/#findComment-4337672
Thanks, I'll keep the Hauppauge bookmarked till I can buy it.
Good man! :D
https://linustechtips.com/topic/319109-usb-tv-tuner/#findComment-4341722
