Motherboard BIOS problem (?)
Go to solution Solved by Master Disaster,
@pedrocnc
First try and reset the CMOS, it might just be a configuration issue.
Let me know if that doesn't work.
Hey guys,
I have a Gigabyte H97M-D3H and after I updated my BIOS to version F4 via @BIOS in Gigabyte App Center, I can't enter my BIOS when I press delete on computer starts :S
I googled it, but didn't find anything that could help me.
Anyone had the same problem? How do I fix it?
Thanks <3
https://linustechtips.com/topic/319032-motherboard-bios-problem/
Sorry, that's not my issue :S
I didn't explain it correctly, I think.. Its like if I wait for it to starts, it starts normaly, but if I press delete, nothing happens.. its like is froze and even my monitor goes to energy saving mode
https://linustechtips.com/topic/319032-motherboard-bios-problem/#findComment-4336878
@pedrocnc
Main Rig:-
Server:-
https://linustechtips.com/topic/319032-motherboard-bios-problem/#findComment-4336892
Thanks man, it worked  :D
Enjoy :D
Main Rig:-
Server:-
https://linustechtips.com/topic/319032-motherboard-bios-problem/#findComment-4337395
