HyperX Memory 1600mhz overclock.
Go to solution Solved by harrynowl,
Yes. Just raise the frequency in the UEFI.
Although I'd save your time as you don't really gain all that much from increased RAM speed.
Hi I have an Asus z97-a motherboard, my memory is running at 1600mhz, is there a way for me to overclock my memory?
https://linustechtips.com/topic/318927-hyperx-memory-1600mhz-overclock/
Okay thanks.
