i got 18k, i've seen people get over 20k with a 4790k
http://www.3dmark.com/3dm/6057488?
CPU- i7 5960x MOTHERBOARD- Asus Rampage V extreme RAM- 32gb Corsair Dominator Platinum ddr4 2800mhz GPU-  2X EVGA GTX 980 SC in SLI PSU- Corsair ax860 CASE- Corsair Obsidian 750d COOLING- EK cpu+dual gpu custom loop (ek supremacy evo, dual gtx 980 copper/acetal waterblocks) MOUSE- Logitech g502 proteus core KEYBOARD- Ducky shine 3 cherry mx blue switches and blue LED MONITOR- Samsung u28d590d UHD  STORAGE -  120 gb samsung 850 evo ssd, 960 gb ocz trion ssd OS- Windows 10 pro http://pcpartpicker.com/p/jtP8GX
https://linustechtips.com/topic/318812-low-firestrike-score/
Your score seems about in line with a 4790K and a pair of 980's.
You certainly will be able to improve your score by overclocking those 980's though.
EDIT: derp, I thought you had a 4790K not a 5960X, my bad.
https://linustechtips.com/topic/318812-low-firestrike-score/#findComment-4334102
doesn't 3d mark use the full 8 cores? so shouldn't it be higher than the 4790k?
https://linustechtips.com/topic/318812-low-firestrike-score/#findComment-4334115
Yeah 3D mark does a pretty good job at using all of the cores. Is 3.8GHz all you can get out of your CPU? Push that harder, as well as your GPU's and your scores will improve.
https://linustechtips.com/topic/318812-low-firestrike-score/#findComment-4334119
3.8 is all that i was brave enough to do. my temps are at 47 degrees
https://linustechtips.com/topic/318812-low-firestrike-score/#findComment-4334280
