My motherboard is a MSI A88XM-E45, and was able to over clock my CPU before on my 750k. Although I updated my BIOS I still cannot change the core clock. If I try to use the iffy OC Genie it tells me it can't do anything over a 65W K series APU... WTF
PCPartPicker Link To My Build
My YouTube channel, also check out my Twitch Stream!
Check out my Lastest CS:GO Video!
https://linustechtips.com/topic/318090-problem-with-ocing-860k/
well thats derpy
have you make sure the BIOS is flashed properly?
should you be toucing voltage and multiplier for OC?
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/318090-problem-with-ocing-860k/#findComment-4324814
well thats derpy
It should be... the version when i enter it matches, but I'm not sure if I should reflash it... I don't think I can mess with the voltages. I sent this pic to MSI Support.
https://linustechtips.com/topic/318090-problem-with-ocing-860k/#findComment-4326122
do it in basic bios then is the only solution
The Vinyl Decal guy.
Celestial-Uprising  A Work In-Progress
https://linustechtips.com/topic/318090-problem-with-ocing-860k/#findComment-4326148
