What I'm trying to achieve is multiple values for 1 primary key.
Sort of looks like this
table "student"
student_id = 1
table "course"
// list of courses stored in course_id
table "grades"
student_id = 1
course_id = "ComSci11"
course_grade = 3.0
student_id = 1
course_id = "ComSci12"
course_grade = 3.1
student_id = 1
course_id = "ComSci13"
course_grade = 3.2
I'm pretty sure the problem here is: only 1 course_id and course_grade is allowed per student_id, how do I achieve what I want?
Other info if this matters:
table "student"
student_id (Primary Key)
table "course"
course_id (Primary Key)
table "grades"
student_id (Index)
course_id (Index)
| CPU: Ryzen 5 3600 | MoBo: MSI B450 Tomahawk Max | RAM: T-Force Delta RGB (2x8) 16GB 3200MHz (Black) | GPU: Gigabyte GTX 1660 Ti OC | Case: NZXT H500 (Black) | HDD: WD Black 2TB + Seagate Barracuda 4TB | SSD: Crucial MX500 2TB | PSU: Seasonic GX-550 | Monitor: 3x Asus VC239H |
it tells you EXACLY what the issue is.
Duplicate entry '1' for key 'PRIMARY'
a primary key lets you only have 1 entry of that kind for quick lookups.
so if a row where a collum is 1 exists,creating another one will give you an error
Primary keys are unique. You need to make the student_id field in grades a foregin key with a reference to students.
Edit: Actually, looking at your DB structure, you need a composite primary key for the grade table. However, you will still need foreign key references to the other tables.
Will that composite primary key help me achieve what I want to happen? Shed some light senpai.
Yes, because you want a many-to-many relationship, so each line of the grades table must be unique. The only way to achieve this is to make the key a composite of both the student_id and course_id.
It might look something like this:
CREATE TABLE grade(  student_id INT(4)      NOT NULL,  course_id  INT(5)      NOT NULL,  grade      DOUBLE(4,2) NOT NULL,  CONSTRAINT grade_pk         PRIMARY KEY (student_id, course_id),  CONSTRAINT grade_student_fk FOREIGN KEY (student_id)    REFERENCES student (id)      ON DELETE CASCADE      ON UPDATE NO ACTION,  CONSTRAINT grade_course_fk  FOREIGN KEY (course_id)    REFERENCES course (course_id)      ON DELETE CASCADE      ON UPDATE NO ACTION)ENGINE = InnoDB;
Thanks, I got the idea and I got it working now xD
