Using Way Too Much RAM
Go to solution Solved by windude99,
My system seems to be using an insane amount of RAM while idle and I don't know why.
I've got 8GB of RAM and while having Steam and Google Chrome open watching a YouTube video I get a message telling me that I need to free up memory.
I've tried closing some things that I know I don't need running but I'm not really sure what a lot of them are for and other things just start using more so it doesn't change overall.
I've added some screenshots of my task manager and there is a hell of a lot running but nothing taking up all that much RAM individually but together I'm constantly over 75%.
How do I know what else isn't needed and how do I stop them all running on start up?
Many thanks!
A few things I want you to do:
First, please switch task manager to the view that shows the amount of memory used in MB instead of the percentage. Then, take screenshots again and put them in this thread.
Second, Disable everything in msconfig except for driver programs and your antivirus.
Third, run virus scans with Malwarebytes Anti-Malware Free and Herdprotect. Use the Windows Malicious Software removal to. Run full scans with all fo these (that have the option to do so).
Download links:
Makwarebytes Anti-Malware Free: https://www.malwarebytes.org/
Herdprotect: http://www.herdprotect.com/
http://www.microsoft.com/security/pc-security/malware-removal.aspx
A few notes about Malwarebytes Anti-Malware Free:
1. Be sure to uncheck the free trial of the pro version of Pro in the installation.
2. Go to gettings and click on "Detection and Protection." Then, click on "Scan for rootkits."
Many thanks!
post-139424-0-90294200-1424908234_thumb.
post-139424-0-48803300-1424908240_thumb.
post-139424-0-23098400-1424908245_thumb.
https://linustechtips.com/topic/317547-using-way-too-much-ram/
My task manager isnt nearly as filled with programs. I would uninstall and close alot of programs. Also avast seems to be doing something. close it
https://linustechtips.com/topic/317547-using-way-too-much-ram/#findComment-4316014
Avast isn't doing anything?
@55five55 Remove norton, SO bad, Enable a pagefile, disable extensions you aren't using.
https://linustechtips.com/topic/317547-using-way-too-much-ram/#findComment-4316031
I had the same problem before my old system died form a hard drive failure (user error). I couldn't figure out the problem, so I closed as much programs as possible with out hurting anything, and uninstalled miscellaneous items on my hard drive. After this I cleared my startup programs and only made the important tasks open up. This mostly cleared it. It started coming back but that's because I installed a bit to many games on steam and my cousin got on my system and wreaked havoc. Then my computer died.
https://linustechtips.com/topic/317547-using-way-too-much-ram/#findComment-4316063
avast is at the top of the memory hog below chrome so.
https://linustechtips.com/topic/317547-using-way-too-much-ram/#findComment-4316072
Many thanks!
Download links:
System: HP Pavilion P7-1010 Upgraded... CPU: AMD Athlon X4 645 3.1ghz, RAM: 6gb DDR3 1066mhz, GPU: Sapphire Radeon HD 5670, PSU: Seasonic S12 II 380w Bronze, SSD: Samsung 840 Evo, HDDs: WD Caviar Green 1tb 5400RPM, Seagate Barracuda 1tb 7200RPM, Case: Generic HP case, OS: Windows 7 Professional 64Bit SP1
2nd Best: Dell Dimension 5100 Upgraded: CPU: Intel Pentium D 945, RAM: 3gb DDR2, GPU: PNY GT440 1gb, HDD: WD 120gb 720RPM, PSU: Seasonic OEM, OS: Win8.1 32bit
https://linustechtips.com/topic/317547-using-way-too-much-ram/#findComment-4316090
Not sure exactly which thing was most helpful but it seems my system is now using a MUCH more reasonable amount of RAM (19% now). Strangely Chrome is now using no more than 4% of my RAM where it was using over 13%.
I ran Malware Bytes which found 2 things, removed Nortons and disabled everything in msconfig other than antivirus and driver programs.
Thanks everyone for the help! :D :D
https://linustechtips.com/topic/317547-using-way-too-much-ram/#findComment-4316508
