Sapphire 7790 Issues
Go to solution Solved by MarioCardona1981,
Well it seems that the card was defective. I went to the store where i purchase it after a week having this problem , they gave me a new card and with the new card and i didnt had any issues so far, no driver issue or crashing , on gaming the card runs great
I just bought a 7790, my previous card was a nice card 6670, worked great but it was time for an update, the problem with the HD 7790  is that sometimes when I'm surfing the internet using google chrome i get this message: "AMD / ATI Video Driver has stopped working properly. ", i get this message only when im using google chrome, not when im playing any game.
I check the temps and everything is fine, my psu is not great but i think its enough to handle the card , i checked the temps and everything is fine.
my specs:
CPU: AMD Phenom II 955 BE 3.2 (no OC)
RAM : 8gb ddr3
VGA: Sapphire 7790 1gb ddr5 dual-x OC (stock speed)
Motherboard: MSI NF725m-p43
PSU: Thenmaltake TR2 600w
I have the drivers up to date, could this be a driver issue ?
CPU : AMD Phenom II 955BE @3.2ghz : 2x4gb ddr3 1333mhz : Video card : Sapphire Radeon HD 7790 Dual-X OC : Motherboard : MSI Nf725m-p43
PSU  : Raidmax RX-735AP : OS : Windows 7 Professional x64 / W8 Pro x64
https://linustechtips.com/topic/31717-sapphire-7790-issues/
Two options. Reinstall your video drivers, or reinstall Chrome.
https://linustechtips.com/topic/31717-sapphire-7790-issues/#findComment-405418
Already reinstall my drivers, im reinstalling chrome now .........
thnx fro the reply
https://linustechtips.com/topic/31717-sapphire-7790-issues/#findComment-405424
If reinstalling Chrome doesn't work, what happens if you disable Hardware Acceleration?
https://linustechtips.com/topic/31717-sapphire-7790-issues/#findComment-405438
I disabled hardware acceleration yesterday , still having the problem.
finish reinstalling chrome, no issue so far ....
https://linustechtips.com/topic/31717-sapphire-7790-issues/#findComment-405476
Post back here with results after 5-15 minutes or whenever the issue starts again(if it does).
https://linustechtips.com/topic/31717-sapphire-7790-issues/#findComment-405483
the thing is that it can pass a few minutes or hours,the issue is random, ill reply if the issue occurs again
https://linustechtips.com/topic/31717-sapphire-7790-issues/#findComment-405501
Do you overclock ?
PRIMARY NVIDIA PC
("I'm a Fanboy of Everything")
| CPU - i5-4670K @ 4.8ghz | CPU Cooler - Antec Kühler H2O 620 | GPU(S) - BIOS MODDED Twin GTX 770 4gb (Gigabyte)-master (Zotac)-slave @ 1337/2000 (8000 Effective) | Mobo - MSI Z87 GD65 Gaming | PSU - Corsair TX850M | Ram - 8gb Gskill RipjawsX @ 1866Mhz | Monitor - Samsung 27" 550 1080p 75Hz | Keyboard - Razer Black-Widow Ultimate 2013 | Storage - 2x 1TB WD-Blacks' | Mouse - AzzA Mouse Would Say "SQUEEKSQUEEK"|
SECONDARY RADEON PC
| CPU - A10-6800K @ 4.6ghz | CPU Cooler - CM Hyper EVO 212 | GPU(S) Twin Radeon 270x 2gb @ 1115/1500 (6000 Effective) | Mobo - MSI FM2-A85XA-G65 | PSU - Logisys 750W | Ram - 8gb @ 1600mhz | Moniter - Acer 24'' 1080p 60Hz
https://linustechtips.com/topic/31717-sapphire-7790-issues/#findComment-405908
Do you overclock ?
no
https://linustechtips.com/topic/31717-sapphire-7790-issues/#findComment-405983
it happened just now :/
https://linustechtips.com/topic/31717-sapphire-7790-issues/#findComment-406165
Does it happen with other browsers, such as Firefox?
https://linustechtips.com/topic/31717-sapphire-7790-issues/#findComment-406168
Try a different PCI-E slot.
| CPU: INTEL i5 6600k @ 4.6Ghz @ 1.328v | Motherboard: ASUS Z170-AR | Ram: G.SKILL 2x8GB 2400Mhz | CPU Cooler : Corsair H100i V2
| GPU: GIGABYTE GTX980Ti G1 GAMING | SSD: SAMSUNG 840 EVO 250GB  Storage: WD 1TB GREEN | OS: Windows 10 Pro 64bit | PSU: FSP 650W AURUM S |
<<<<< BLK-Phant0m >>>>>
https://linustechtips.com/topic/31717-sapphire-7790-issues/#findComment-406184
not yet, i tested a few hours ago but nothing, i cant figure it out what is triggering this problem............
https://linustechtips.com/topic/31717-sapphire-7790-issues/#findComment-406186
The motherboard only has one PCI-E slot, it's a low end motherboard
https://linustechtips.com/topic/31717-sapphire-7790-issues/#findComment-406189
the only thing left to try is reinstall windows ..........
https://linustechtips.com/topic/31717-sapphire-7790-issues/#findComment-406191
I guess.
https://linustechtips.com/topic/31717-sapphire-7790-issues/#findComment-406205
update your drivers possibly.
PRIMARY NVIDIA PC
SECONDARY RADEON PC
https://linustechtips.com/topic/31717-sapphire-7790-issues/#findComment-406230
Things I already did:
1-) Reinstall drivers
2-) Download and install performance drivers ( made things worse, driver began to crash every 5 minutes)
3-) Reinstal gogle chrome
4-) Disable hardware acceleration, still having problems
5-) I played Dead Space 3 yesterday for a while and worked great
please help :/
https://linustechtips.com/topic/31717-sapphire-7790-issues/#findComment-407685
I found this because im about to buy a 7790 myself... LOL. Try uninstalling the drivers again, then run Ccleaner after its done uninstalling, On Ccleaner run both the Cleaner and Registry options... Try that to see if it works.
You can download Ccleaner from: http://www.piriform.com/ccleaner/download/standard
I recommend you also just have on your PC after... Its a really great tool!
CPU: AMD FX 6100 Stock - MB: Asus M5A97 EVO - RAM: AMD Memory Entertainment Edition 2x4 GB 1600 MHz - PSU: Topower 650W NANO - SSD: Samsung 840 120GB - HDD: Seagate Barracuda 500 GB 7200 RPM - GPU: Sapphire HD 7770 Vapor - X OC - CASE: Aerocool Strike - X Advance (Red/Black) - OS: Windows 7 Ultimate x64
https://linustechtips.com/topic/31717-sapphire-7790-issues/#findComment-408418
And you can try uninstalling chrome also, just in case ;)
https://linustechtips.com/topic/31717-sapphire-7790-issues/#findComment-408446
I already run Ccleaner when i uninstall the drivers
I reinstall chrome and still having the problem, Im using Firefox now , no problems so far
reinstall chrome and the problem was still
In using firefox rith now , no issues so far,
https://linustechtips.com/topic/31717-sapphire-7790-issues/#findComment-408773
I already did that, and stil having the problem
I reainstall chroime , and the problem wont go away, im using Firefox now, no problems so far
Edited by MarioCardona1981
https://linustechtips.com/topic/31717-sapphire-7790-issues/#findComment-408777
Thats very weird. The last thing I can think of is if you go to Ccleaner (again LOL) go to Tools - Startup and go to the tab that says Google Chrome. There try to find anything related to AMD drivers or something, and if you find anything disable it. If you dont find anything then I just recommend you install W7 again and get it over with  :wacko:
https://linustechtips.com/topic/31717-sapphire-7790-issues/#findComment-408820
I guess i should install W7, it is the only thing that i havent tried, same result using firefox ....................
https://linustechtips.com/topic/31717-sapphire-7790-issues/#findComment-409033
I just install W7 and the problem continues .........
i guess that is a driver issue :/
https://linustechtips.com/topic/31717-sapphire-7790-issues/#findComment-413425
