I'm currently using the Stock Intel fan that came with my i5 4960 (non-k). I don't like it. The case I've got is a Coolermaster K280.
http://www.ebuyer.com/414618-cooler-master-k-series-k280-usb3-0-atx-case-rc-k280-kkn1#
Price for the CPU Cooler £15-20
The Hyper evo 212 is 160mm so it will have on 2mm of clearance in the case. :/
Thanks.
https://linustechtips.com/topic/317112-cpu-cooler-less-than-162mm/
What's the question?
The Hyper 212 Evo fits
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
Looking for a new CPU Cooler. :)
Get the hyper 212 evo?
Main Rig
Phone
2mm of clearance is fine.
I'd suggest spending a bit more for a much quieter cooler if possible: http://uk.pcpartpicker.com/part/be-quiet-cpu-cooler-bk009
Read my post again. :P
You say it has 2mm of clearance? I don't see the issue
Main Rig
Phone
Okay. Thanks.
Quieter versions of the Hyper 212 EVO pretty much.
(P.S You can fit the Hyper 212 EVO, that is enough space.
Option 1:
http://www.overclockers.co.uk/showproduct.php?prodid=BG-014-AL&groupid=595&catid=678
Option 2:
http://www.overclockers.co.uk/showproduct.php?prodid=BG-007-AL&groupid=595&catid=678
I'm gonna get the CM Hyper 212 Evo. :)
It can be quite loud and those are better but ok...
Thanks.
tbh 2mm is enough clearance which is why I think you should get the cryorig h5 one of the only cpu air coolers with 140mm fans that will fit in your case
