Hi again. I'm back. For those of you who are wondering, this is my post yesterday, about my fans going from silent to loud:
______________________________________________________________________________________________________________________________
Note: Sorry in advance. I'm uneducated at this part of technology.
Hi there. I've been noticing something that has been happening to my PC. You see, I cleaned this PC 3 days ago before this happened. What happens is, the fans are spinning very silently (while the computer is on idle, no programs running), and when I open File Explorer or MS Word, it suddenly becomes quite loud, (reaching 4299 RPM, according to HWMonitor). And then it goes to 3110 RPM, and then back to 4000+ RPM.
Another thing I noticed is that the CPU Temperature is actually quite high, reaching 99-100 degrees Celsius. Any problems?
One of you guys told me to re-seat the cooler and apply thermal paste. I managed to get hold of an Arctic Silver 5 (Arctic Silver 5 High-Density Polysynthetic Silver Thermal Compound - full name). The first thing that I did when I got home is to crack the case open and apply the thermal paste. I thought that the problem should now be solved. It wasn't solved. Temperatures still spike up to 100 degrees Celsius. Any problems?
Has a Ph.D in Nothing and does not speak Chinese, Italian or French. (aber ich kann Deutsch sprechen)
https://linustechtips.com/topic/316959-cpu-overheating-problem/
Heatsink is clear, fans spinning at stupid speeds, new thermal paste and yet it is still reaching 100 degrees. I have no idea what to recommend but I do have a question or three ----> What have you done differently if this problem wasn't present before you cleaned the PC out, also what is the usage like when the CPU is at 90-100 degrees because I don't think it is the fan, it must be something putting it under huge load otherwise I have no idea what is going on.
It can't be the fan because it is spinning really fast and moving a bat shit crazy amount of air while doing it, I'd also look into running a full virus scan, it can't make anything worse.
DESKTOP - Motherboard - Gigabyte GA-Z77X-D3H Processor - Intel Core i5-2500K @ Stock 1.135v Cooling - Cooler Master Hyper TX3 RAM - Kingston Hyper-X Fury White 4x4GB DDR3-1866 Graphics Card - MSI GeForce GTX 780 Lightning PSU - Seasonic M12II EVO Edition 850w  HDD -  WD Caviar  Blue 500GB (Boot Drive)  /  WD Scorpio Black 750GB (Games Storage) / WD Green 2TB (Main Storage) Case - Cooler Master 335U Elite OS - Microsoft Windows 7 Ultimate
https://linustechtips.com/topic/316959-cpu-overheating-problem/#findComment-4308218
It may be your case it self restricting airflow to the CPU.
https://linustechtips.com/topic/316959-cpu-overheating-problem/#findComment-4308219
From what I can gather is that it hasn't always done it so I doubt the case is to blame though could be wrong if he has moved it.
https://linustechtips.com/topic/316959-cpu-overheating-problem/#findComment-4308223
Probably. But I think that's impossible because ever since the problem came, I didn't place the side panels back on the case.
https://linustechtips.com/topic/316959-cpu-overheating-problem/#findComment-4308251
The usage when it spikes up to 90-100 degrees Celsius is appalling. There is a delay where if I open File Explorer, it takes about 30 seconds up to a minute just to open it. And I always encounter sudden reboots, probably because of the CPU overheating or something.
https://linustechtips.com/topic/316959-cpu-overheating-problem/#findComment-4308287
Run a virus scan in safe mode, may take a while but leave it to complete.
https://linustechtips.com/topic/316959-cpu-overheating-problem/#findComment-4308310
Fuck well, I don't know. You sure you haven't unplugged anthing by accident
I had a similar problem and it was my case. So I just used that.
https://linustechtips.com/topic/316959-cpu-overheating-problem/#findComment-4308316
As far as my eye can see, all connections are fine, CPU Fan, Case fans, everything.
https://linustechtips.com/topic/316959-cpu-overheating-problem/#findComment-4308333
ok, well i don't know then.
https://linustechtips.com/topic/316959-cpu-overheating-problem/#findComment-4308340
Nothing happened. It didn't detect a virus or anything else. It's probably because the CPU will decrease its performance or else it will burn or something. I know there's a term for that but I forgot.
https://linustechtips.com/topic/316959-cpu-overheating-problem/#findComment-4308896
