I have built a new computer, which is the first computer I have built.
this is my computer:
intel core i5 3330
asrock z77 extreme 3
Kingston ddr 3 2x4Gb
Nvdia gtx 660
cooler master 650w psu
No matter what game I have tried, none of them runs smooth, not even in the lowest settings. I have installed every drives I can.
Can any one help me, pls?
https://linustechtips.com/topic/31694-games-never-ran-smoothpls-help/
the cpu is 36% during gaming. And is 3-4% when not
btw I using win8 x64, does that affects anything?
that could effect old games such as age of empires II... how old is you computer, how long have you used it, did it come with Win8 or did you upgrade,  when did this problem occur
Have you tried Geforce Experience?
One Steam to rule them all, One Sale to find them, One Sale to bring them all and with their wallets, bind them! - r/pcmasterrace 17/01/2014
  • CPU: Intel Core i7 6700k
  • CPU Cooler: CM Hyper 212+
  • RAM: 16GB Kingston HyperX Fury 2400Mhz (2x8GB)
  • GPU: Gigabyte G1 R9 390
  • Mobo: Asus Z170-AR
  • PSU: Antec High Current Gamer 900W
  • Storage: 240GB intel 520 SSD (OS), Sandisk 128GB SSD(Other OS) 2x 2TB Seagate Barracuda
  • Case: Fractal Design R4
Have you checked and made sure you have plugged the monitor into the GTX660, and not the integrated onboard graphics port on the motherboard?
IF you have a list of games you are running and fps you are getting (use fraps) would be helpful.
----Ryzen R9 5900X----X570 Aorus elite----Vetroo V5----240GB Kingston HyperX 3k----Samsung 250GB EVO840----512GB Kingston Nvme----3TB Seagate----4TB Western Digital Green----8TB Seagate----32GB Patriot Viper 4 3200Mhz CL 16 ----Power Color Red dragon 5700XT----Fractal Design R4 Black Pearl ----Corsair RM850w----
The game is new metro:last light, mlb2k13 and deadpool
The computer is recently assembled which does not exceeds 1 month old
The win8 was the box version which I purchased and installed to the computer as the first operating system on it.
This problem had never been fixed and occurred since I installed and started the first game I wanted to play.
And thank you for helping
I am sure it pluged in the right one.
I have tested with metro:last night, I have set 1280x720 and everything turned off.I have got around 15~20fps. The maximum is 24fps
Thank you for checking my question
unless you plugged it in the wrong port your gtx660 is defective, are you absolutely 100% sure you plugged the monitor into the right port?
CPU: i5 2500K @ 4.2GHZ, GPU: AMD Radeon RX 480 4GB, RAM: Corsair Vengeance 8gb (2X4GB) 1600MHZ, Mobo: Asus P8Z77M, Chassis: Phanteks P400s Tempered Glass editionStorage: Seagate 1TB + Samsung 2TB In RAID 0 + Crucial MX100 256GB SSD, Sound Card: Asus Xonar DS, Mouse: Steelseries Sensei, Keyboard: CM Storm Quick Fire Pro, Monitor: BenQ G2410HD + Samsung SA1900
I have a 4670k and a 660ti with 8gb ram and metro last light runs at about 70fps average on very high, no ssaa and no tesselation at 1920x1080 so im not surprised your saying metro doesn't run smoothly, It's playable on mine and i have quite a difference in hardware specs, Metro last light is a very demanding game, Are you sure you haven't got vsync on in all your games? If it's off go into the  nVidia control panel and turn any vsync off and getting the geforce experience from nvidias website will help in optimizing your settings in games
I think your gpu has called it quites, i think intergrated would run better then that or your put the port in the the motherboards my accident and as a result your crap has gone to hell as its not using the gpu at all.
Listen if you care.
Is the monitor port connected to your motherboard or is it connected to the back of the graphics card.
Listen if you care.
I had an issue where after switching graphics cards my games were a bit choppy, what I did to fix my issue was to load windows in safemode and uninstall the graphics drivers (tried in normal windows but didn't fix the issue until I did it in safemode).
Once I had done that then restart the pc and install the graphics drivers again.
It was a strange issue but this is what fixed it for me.
Are the power cables plugged into the GPU? Is the monitor plugged into the back of the GPU? Last Light is a  very demanding game btw... With my setup I would get like 20 fps.
| i5-4670k @ 4.2Ghz | Corsair H100i | Gigabyte Z87X-UD4H | Corsair Vengeance Pro 8GB | ASUS Geforce GTX 770 |
| Samsung 840 Pro 128GB | WD Black 1TB | Corsair AX760 | Fractal Design Define R4 Black w/ Window | Corsair AF140 x2 |
| Windows 8.1 | ASUS 23" 1080p monitor | CM Storm Quickfire Stealth- MX Blue | Logitech G9x | Logitech G930 |
Also, have you installed all of the necessary drivers? Like the Motherboard, GPU... We need to know all of this to diagnose the problem with your pc.
its sounding more and more like the gtx660 is goosed then....
Go to speedtest.net and see if you computer is slow or download speed is bad and how old is your computer, it may be you need recheck your setting to your max speed
        # -_-     [Planned RIg AKA Project ARES    -_-#
| AMD FX-8350 4.0GHz 8-Core | Be Quiet DARK ROCK 2 57.9 CFM Fluid Dynamic Bearing | Asus Crosshair V Formula-Z  |G.Skill Ripjaws X 8GB Western Digital Caviar Black 1TB 3.5" 7200RPM |Samsung 840 Series 250GB 2.5" SSD | Sapphire Radeon HD 7970 3GB  |Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower|Gelid Solutions Silent 14 PWM 74.5 CFM 140mm x3 |Corsair RM Series 750 Watt ATX/EPS 80PLUS Gold-Certified Power Supply|
|Rosewill RNX-N250PCe | Windows 8  | Acer H236HLbid 23.0" |Corsair Vengeance K70
Corsair Vengeance M65 Wired Laser | STEELSERIES QCK Black|Sennheiser HD 558Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
What good is checking his internet speed to help get a game working???
CPU: AMD FX-8350 | CPU Cooler: H80i | Motherboard: Asus M5A99FX PRO R2.0 | RAM: 8GB Kingston Beast 1866MHz
Case: Define R4 | GPU: Gigabyte GTX 780ti | PSU: Corsair CX600M | SSD: 250GB Samsung 840 EVO
.... and a Partridge in a pear tree!
first open the case and check the wires. make sure that the gpu is plugged into the top most pci-e slot on the motherboard. connect the monitor to the gpu output, not the 1 attached to the motherboard. boot the system and go into bios look for the pci-e settings and set it to peg 1 or what ever is used to set the gfx to the first pci-e slot and disable cpu/gpu at the same time. save and quit. reboot and hope you see a signal on your monitor.
Rig: Intel i7 920 D0 @3.5 | gtx970 | 12 gig Balistix 1333 @ 8-8-8-24 | 2x1TB Spinpoint F3 Raid 0 | 1TB Spinpoint F3 |samsung 840 evo|  Thermaltake 850w Tp |
Xfi extreme gamer | Antec 902
Peripherals: Samsung syncmaster 2494hs @1920/1080 - 60Hz | Q-pad MK85 | g502 | Razor Destructor | Logitech G930 | Logitech 3D pro xtreme | 360 pad | Nitro Wheel
I don't really know but in my experience when my internet speed is faster my game works better I guess that's how  taught
