DNS does not work
Guest Haduvokone
Go to solution Solved by flexin1981,
Could you send me the DNS name that you are using and the IP that you have on your router please.
You can do this on a PM if you wish
Hello, i host a website at home (please don't blame me this threat isn't about that) but anyway the ip works fine i forwared but just bought an dns for it but it doesn't work does anyone now why? and i may host from my isp really so does anyonenow what it is?
-thanks!!!
if i have to give info no problem! :)
https://linustechtips.com/topic/316536-dns-does-not-work/
default dns? sorry i am new to this stuff i do know how to ping :)
Ehm... Did you said you host a website at home? Better host your website on a hosting service provider if it is for public views. Its easy to snoop in and exploit your data. If it is hosting on a non-isolated network/computer. Unless you're using it for your own use or friends. Create a intranet and vpn to share among the few of them.
https://linustechtips.com/topic/316536-dns-does-not-work/#findComment-4302196
please sorry but i disscused it with my isp it's alright in my situation
https://linustechtips.com/topic/316536-dns-does-not-work/#findComment-4302237
this?  Host Name . . . . . . . . . . . . : computer
 Primary Dns Suffix  . . . . . . . :
 Node Type . . . . . . . . . . . . : Hybrid
 IP Routing Enabled. . . . . . . . : No
 WINS Proxy Enabled. . . . . . . . : No
 DNS Suffix Search List. . . . . . : home
https://linustechtips.com/topic/316536-dns-does-not-work/#findComment-4302359
http://www.wikihow.com/Enable-IP-Routingdo this first.
Any dns server address? Y/N?
https://linustechtips.com/topic/316536-dns-does-not-work/#findComment-4302369
Who setup the DNS for your domain....
Do you have your SOA record setup?
Do you have all your A records pointing to your public IP address?
If you are NAT 'ing internall do you have the proper ports forwarded to the correct internal IP address?
Can Anybody Link A Virtual Machine while I go download some RAM?
https://linustechtips.com/topic/316536-dns-does-not-work/#findComment-4310593
