Help with binary to decimal
Go to solution Solved by Guest,
It is java, there is a tag at the top.
If I out in 101 it does 5 correctly, but if I put in 110001 (49) It will return 35 which is 100011. I belive this is the cause for my other problem which is it ignores 0's at the begining or end, making it return 1 if I put in 100.
Ok. How's this:
public String binaryToDecimal(int binary) {  result = 0;  String binaryString = String.valueOf(binary);  for (int i = 0; i < binaryString.length(); i++) {    if (binaryString.charAt(i) == '1') {       result += pow(2, (binaryString.length() - 1) - i);    }  }  return Integer.toString(result);}
I think the problem is that you are going through the string from left to right, but the least significant bit is on the right.
I am trying to make a program that will change binary numbers to decimal, but it is not working and I am not sure why. It seems to be reversing the order of the input and therefore ignores 0s if it ends with one. I have the opposite of this working with the same square method, so I think it is just a problem with the conversion.
public void calc(int a) {
output1 = 0;
String input = String.valueOf(a);
String in[] = new String[input.length()];
for(int k = 0; k < input.length(); k++) {
in[k] = input.substring(k, k + 1);
for(int i = 0; i < input.length(); i++) {
if(in.equalsIgnoreCase("1")) {
int j = square(i, 2);
output1 = output1 + j;
label1.setText(Integer.toString(output1));
input1 = 0;
public int square(int a, int b) {
if(a == 0) return 1;
int total = b;
for(int i = 0; i < a - 1; i++) {
total = total * b;
return total;
http://pcpartpicker.com/p/9DNjLk I like the night theme, it complements my dark basement. If you are reading this then you must also be a fan of the night theme.
01011011 01000010 01101001 01101110 01100001 01110010 01111001 00100000 01001000 01100101 01110010 01100101 01011101
https://linustechtips.com/topic/316144-help-with-binary-to-decimal/
For readability.
public void calc(int a) {  output1 = 0;  String input = String.valueOf(a);  String in[] = new String[input.length()];  for (int k = 0; k < input.length(); k++) {    in[k] = input.substring(k, k + 1);   }  for (int i = 0; i < input.length(); i++) {    if (in[i].equalsIgnoreCase("1")) {       output1 += square(i, 2);    }  }  label1.setText(Integer.toString(output1));  input1 = 0;}public int square(int a, int b) {  if (a == 0) return 1;  int total = b;        for (int i = 0; i < a - 1; i++) {    total *= b;  }  return total;}
So I'm not entirely sure what language this is, I'm guessing C++?
Can you give some example inputs and the output that you are getting with the code as it is? I don't really understand why you are squaring anything as binary is based on a power-of-two system.
Ok. How's this:
Ok. How's this:
Your code helped me figure out what I did. I was using 2 for loops, leaving a lot more area for errors. I made your code fit into my program and it works fine now. Thanks
