Will my system be bottlenecked?
Go to solution Solved by SteveGrabowski,
Im only targetting 60FPS as I have a 60HZ 1080p monitor.
By the way will a GTX 970 with this CPU be able to play all currently available games at ultra settings at 1080p?
You might occasionally have to bump a setting down a little from Ultra, but for the most part you should be playing games at 1080p Ultra with close to a locked 60 FPS with that setup. I have a GTX 970 + Xeon E3-1231v3 (pretty much an i7-4771 minus 100MHz and with no integrated graphics) and it's great for playing new games at 60 FPS. Crysis 3 I'll get lots of sections in the 50s and some 40s on Very High system spec, and Far Cry 4 Ultra I'll sometimes have drops into the 50s (especially late night turning to morning), so I play it on the Very High preset instead. But stuff like BF4 and Dying Light run great maxed out (except draw distance on Dying Light, but that's a CPU limitation I think).
It'll run just fine the 970 is a mid Range card. Hell, probably a 980 wouldn't bottleneck or at least a 980 wouldn't bottleneck much,..
My System has a Intel Core i7 4790k @4.5ghz Cooled by A Cooler Master Hyper 212 EVO With a MSI Nvidia GeForce GTX 1080 Founders Edition and 16GB of Corsair Vengeance 1600Mhz Memory.
The word "bottleneck" doesn't exist on Intel's dictionary.
Corsair 760T White | Asus X99 Deluxe | Intel i7-5930k @ 4.4ghz | Corsair H110 | G.Skill Ripjawz 2400mhz | Gigabyte GTX 970 Windforce G1 Gaming (1584mhz/8000mhz) | Corsair AX 760w | Samsung 850 pro | WD Black 1TB | IceModz Sleeved Cables | IceModz RGB LED pack
Appreciate the help guys. Somebody at tomshardware forums said that i might experience bottlenecks so I posted my question here just to get a second opinion.
Don't use Tom's Hardware. I used to use it, but the people here are more intelligent than over there.
The i5-4430 is a great CPU and you should be golden if you're targeting 60 FPS. If you're targeting 120 FPS with SLI then you'd be better off with an i7-4790k or i7-5820k.Im
As someone with an i5-4590 and a GTX 970, yes.
...Except AC:Unity.  But even then I get a solid 60fps/1080p on Ultra with AA turned down.
No, not the 5820k. Not hating on it, but the 4790k has much better single core performance, which games most likely seek
