Putting my build together and had a question about a Cable: Corsair CX750M PSU with these cables the 6-8 Pin connector to the PSU is blue and labeled
txm/hx series only, my PSU has no matching blue 6-8 Pin connectors will this cause any issues when connecting my GTX 980?, As far as i can tell the cables should be Compatible.
http://www.corsair.com/en-us/professional-series-hx-enthusiast-series-txm-builder-series-cxm-individually-sleeved-modular-cables-black
Corsair PSU Compatibility:
  • HX Series – 1050/850/750/650
  • HXi Series – 1000/850/750
  • TXM Series – 850/750/650
  • CXM Series – 750/600/500/430
  • RM Series – 1000/850/750/650/550/450
  • AX Series - 860/760
  • AXi Series - 1200/860/760
https://linustechtips.com/topic/315683-help-build-question/
How did you get a PCI-E 6-8 pin cable with your CX series that was designed for the HX series? I'm not quite sure, but if you indeed do have a 6-8 pin connector from the HX series, you really shouldn't plug that into your CX series PSU.
CPU i5 3570k MOBO Asus Maximus Gene V GPU Asus DCUII 670 CASE Corsair 350D (windowless) SSD Crucial M550 256GB msata CPU COOLER Noctua NH-D14 RAM Corsair XMS3 8GB 1600mhz PSU Corsair AX750 Display Asus PB287Q 4K (my review on it http://linustechtips.com/main/topic/380533-journey-into-4k-goodness-asus-pb287q-review/) & Asus VH236H 1080P
Keyboard Logitech G710+ MX Brown Mouse Logitech G502 (my review on it http://linustechtips.com/main/topic/299464-logitech-g502/ )
Proud owner of a BlackBerry Q10.
https://linustechtips.com/topic/315683-help-build-question/#findComment-4290493
